Batmobile goes 10.67 on 23psi
did you ever say what size injectors it has? with a single walbro and PTE 1000cc I was seeing 108% IDC...I could see sqeezing a little more out if I were running c16 and leaned the AFR out a bit. If that car traps 133 on 23psi then it's really going to fly when the boost is cranked up once it had an adequate fuel supply. (twin pumps).
For reference I went 135 on 93 octane (full weight car) with twin walbros and 1000cc injectors the IDC was 92% but I needed 32.5psi-34.5psi to do it. If I dropped my boost to 23psi and ramped the timing way up I doubt seriously I'd be able to trap 135. I'm still amazed and what your car can do...very impressive.
880's? I saw 117% IDC with 880's on a single walbro when my car only trapped 125. Is the base fuel pressure cranked to the moon to make them flow better or is the AFR extremely lean?
133mph traps on a single walbro and 880cc injectors at 23psi leaves me completely baffled unless the car was super light weight (not making that much power) and I think it was already said that this is not a gutted car. Help me understand this
I know I explained this earlier, but it didn't sink in.
LET ME BE CLEAR...That is NOT a sarcastic comment. I'm serious I am going to explain again because some may not have understood the first time. I am not calling anyone stupid, because THIS is a productive and legitimate question.
The efficiency of this engine, with the combination of parts we designed and installed, is extremely high. Unlike what others have marketed before on this forum. I mentioned this in an earlier post I believe in the beginning of this thread. BSFC rates are at least 12% better and the engine as a whole makes great use of every ounce of air and fuel it processes. Now we mention again in the thread that it was immediately apparent he was out of fuel at 23psi. Meaning in the AEM Logs we saw 97% at 7200 rpm. It brought his total average AFR up. At peak torque we ran 11.1 AFR in third gear. By 7000 rpm it was climbing to 12.0. On pump fuel.
We only tested the car to 7000 on the dyno. At the track he started shifting at 7-7200. But he would run out of 4rth gear. Those runs were good for 11.1-11.3 at 125-128 MPH letting off in 4rth.
Also another reason I recommended running some race fuel to see if we could safely run anymore rpm to hit our goal of holding 4rth thru the traps.
I understand that it seems a bit much to believe but it is what we have been running for some time on many cars. If anything it should ADD credibility to the argument, because we were only running 880cc injectors. 23 psi is all the boost it would take safely in my eyes.
Timing is not conservative, but it isn't radical either. There is quite a bit left on the table. I would venture to say about 25-30 HP in timing alone with nothing but race fuel. But that's about it.
I have a customer car that we built that ran 10.71 at 127 @ 23psi with a crappy 1.72 60' on street tires.
Mods as follows:
AEM EMS
Standard BB 35R
Kelford 272 cams
stock head
stock tb
built 2.0L bottom end
1600cc/min injectors
1 walbro 255
E85 as fuel
Take that for what it is worth.
Mods as follows:
AEM EMS
Standard BB 35R
Kelford 272 cams
stock head
stock tb
1 walbro 255
E85 as fuel
From my simplistic perspective, the more advance you run, the more complete of a fuel burn you will get? So if you are favoring timing over boost, you might have better efficiency in terms of fuel consumption?
Just a thought. Maybe I'm way off.
Oh and what parts are making this car efficient? The head design from HeadGames and what else if you don't mind me asking.
Again you heard one word and that is all you got from it. It is not just a cylinder head that came from fairy land. As I explained, and yet again you did not read the thread obviously, there are many factors. Some and not limited to are our Head Chamber and Port design that we developed with Headgames, DTM Cam profile, Piston design and dish volume, Quench area, Valve train, Turbo Manifold Design, and turbine efficiency.
Lets not forget TUNING!
On another note, you are assuming we are favoring timing over boost. THAT IS VERY FAR FROM THE TRUTH. If we could run more boost we would. Our theory on timing lead is not add a bunch and run low boost. That is ludicrous. Its probably as stupid as the people who think they can put race fuel in the car and it will magically sprout more WHP from the type R sticker on the trunk....
More advance does not mean anything. The right amount of advance is more like it. Every load and and rpm cell require a specific lead numerically. Just by saying more advance does not mean anything and it may do nothing. Fuel doesn't burn "more completely" by adding timing. You burn the air fuel charge completely when all the variables in the chamber are in harmony. We are not going to make this a theory thread, but suffice to say many factors go into making an efficient burn.
I guess I had a simplistic perspective that a high boost low timing car will have a less efficient burn because you do see EGT's increase as timing is retarded. This tells me perhaps some energy is escaping as a by product as opposed to something of use. But I can't say I understand the intricacies of all the things like tumble and squish and what not.
Does the OP's customer car have custom DTM pistons and cams? Cool! Sorry I focused on the head. It was not intentional.
Pistons are 9:1
Fuel has been discussed in uber amounts. He was running literally a full tank of fuel 8 gallons of 93 and the rest filled the tank with C16.
It seems to be very difficult for people to understand that there is ALOT more to building an engine that just "dropping" in pistons. For now I guess people will never be able to read between the lines. I have posted it in black and white thru this thread.
Amazing...
Amazing...
regular 9:1 pistons and as Nick just stated (well he actually did about the pistons too) but it was 8 gal 93 and the rest c16. Not that hard to believe. Also have a driver mod with bald street tires.
There are quite a few more factors that would play into why this car runs so well for what it is. Head flow, cams, etc, etc. It's def. not all about what's in the bottom end. It is a very well built, and very well put together setup that works flawlessly.
Damn impressive so far so keep it up.
