Batmobile goes 10.67 on 23psi
Old Dec 5, 2008 | 05:52 AM
  #76
Sharkbite2000's Avatar
impressive!!
Old Dec 5, 2008 | 05:56 AM
  #77
DTM's Avatar
DTM
Originally Posted by crcain
By the way, remember that pump gas dyno war you started with Buschur?
Whatever happened to that? What is the fastest pump gas customer car you have turned out since then?
Pump gas war "I started with Buschur?"
Lets see, I believe we started a thread about a car we built that made more power than anyone else on pump fuel. We jokingly called it a record. Of course some peoples feelings were hurt and it went the way it always goes on this forum. A war? I don't think so, but we will defend our work and ethic. Just as david has done in the past for himself and his customers.
Speak about things you understand and read about things you don't. You haven't figured out how to keep the gums from flapping on issues or topics you should be yearning for information on.
Joe easily went 10.8 after he figured out how to get the 1-2 shift down after the car would spin thru the gears. After that he never got a shot to go faster. Track had a spill and they never ran again. Until next season, I guess. Is his time of almost 135 not good enough either? Or are we hiding some magical potion behind this curtain as well.
I guess I am coming off like an ***, but it has been many years and times over we/I have had to prove ourselves. Its almost stupid ridiculous now.
Merry Christmas Everyone
Old Dec 5, 2008 | 05:58 AM
  #78
DTM's Avatar
DTM
The run was done with a race gas mix. End of story.
BTW It just occurred to me, It wasn't a secret....
Old Dec 5, 2008 | 06:25 AM
  #79
Indy Evo's Avatar
Is it just me or did another perfectly good thread get ruined by crcain again.
To the OP great job getting to the track and running those numbers. Contact a Mod and have them scrap the last two pages of this thread.
Good Luck, Indy
Old Dec 5, 2008 | 06:54 AM
  #80
DTM's Avatar
DTM
Good Luck, Indy
No its not just you, Indy... Hopefully we will get back on topic.
Good job on the run Anthony! I will get that 10.67 run off the mini dvd here shortly and post it for you.
Old Dec 5, 2008 | 06:56 AM
  #81
vaboostn33's Avatar
hahahaha this ish is too funny. for the ones who gave me props thank you. for the ones who dont i could care less. if you want then you can come to the shop and see for urselves. the car is on 2 3psi with stock ignition stock TB stock IM and one pump. its a standard 3582. Indy, thank you. It doesnt really bother me tho. iv gotten this since day 1and i love it. just makes me wanna go faster to **** people off. if i woulda known people would get this panty hurt then i woulda got some slicks and have some people dont kno what to do with themsleves. i dont think nick coulda said it any better by sayin.......keep em commin. this keep me entertained at work.
Old Dec 5, 2008 | 07:05 AM
  #82
Mellon Racing's Avatar
did you ever say what size injectors it has? with a single walbro and PTE 1000cc I was seeing 108% IDC...I could see sqeezing a little more out if I were running c16 and leaned the AFR out a bit. If that car traps 133 on 23psi then it's really going to fly when the boost is cranked up once it had an adequate fuel supply. (twin pumps).
For reference I went 135 on 93 octane (full weight car) with twin walbros and 1000cc injectors the IDC was 92% but I needed 32.5psi-34.5psi to do it. If I dropped my boost to 23psi and ramped the timing way up I doubt seriously I'd be able to trap 135. I'm still amazed and what your car can do...very impressive.
Old Dec 5, 2008 | 07:10 AM
  #83
vaboostn33's Avatar
i cant remember which ones i put in. im sure nick can tell you but they are 880's.
Old Dec 5, 2008 | 07:15 AM
  #84
880's? I saw 117% IDC with 880's on a single walbro when my car only trapped 125. Is the base fuel pressure cranked to the moon to make them flow better or is the AFR extremely lean?
133mph traps on a single walbro and 880cc injectors at 23psi leaves me completely baffled unless the car was super light weight (not making that much power) and I think it was already said that this is not a gutted car. Help me understand this
Old Dec 5, 2008 | 07:32 AM
  #85
vaboostn33's Avatar
ill let nick explain all the idc non sense. but the only thing i took out of the car was the carpet and headliner. the car still wieghs 3300 without me in it n im a big dude. if you go to my myspace link there is plenty of pics of it there.
Old Dec 5, 2008 | 08:09 AM
  #86
no problem
that's probably what my car weighs without me, I removed the spare tire, jack, installed the mini battery and removed the front crash bar.
Old Dec 5, 2008 | 08:36 AM
  #87
PATRICK B.'s Avatar
That brings up a good point on the approach to the tune > timing/low boost vs <timing/high boost.
I was just discussing this with my tuner as he tends to be a bit more conservative on the timing and prefers to incerease boost pressure on my car at least.
Regardless great times no matter what and fwiw on 1000's and 1fp = 100%idc at 34psi
Now with 1200's and 2 fp's the idc's i bleieve were in the 85% range at 8500rpm and 37ish psi.
Old Dec 5, 2008 | 08:46 AM
  #88
Evolution IVGSR's Avatar
Sick very impressive man {thombup}
Old Dec 5, 2008 | 08:57 AM
  #89
vaboostn33's Avatar
^thank you. I was looking at your fs thread the other day. your car is sick as **** man. GL with the sale. If i wasnt a baller ona budget id scoop that thing up ina heartbeat!
Old Dec 5, 2008 | 09:07 AM
  #90
good info...you have to consider the AFR when speaking about IDC....race gas guys may be running 12.0-12.5 which can drop the IDC considerably. I run pump gas and can't get away with that at high boost.
