Underpanel and Trap Speeds
I basically just wanted to know how much does not having and underpanel affect you at the track.
Anyone tested this?
How much mph would you gain with the addition of a beatrush or even stock underpanel vs none?
Just wanted to know because I have been running without one for a while and wanted to see how much it was slowing me down.
Thanks
Anyone tested this?
Thanks
Portions of this thread might be useful: https://www.evolutionm.net/forums/sh...d.php?t=381904
The implication for trap speed on the strip may be about rear diffuser more than any front underpanel.
i remember the review on the beatrush underpanel and they said that at the track they saw an increase of 15mph in the straights. Although I'm pretty sure that's combined from the whole track and not just one straight.
A test would be good to see just how beneficial it really is.
i think someone on this forum had mentioned something about a 'parachute' effect of the rear USDM bumper which makes sense short of because of the design...
if air passes under the car the air can be trapped under the rear bumper thus maybe braking the car... MAybe? thats theory but it would be cool of someone could actually test it....
An easy and most cost effective way to relieve this "parachute" effect the USDM rear bumper presumably causes would be to cut two air ducts. One on each side to allow the once trapped air to flow right through. I'm sure this could be done in a very cosmetically pleasing way as well.
Also I would think the whole from the exhaust already relieves some of this pressure, but of course the air would have to go around the exhaust still causing inefficiency.
A very simplistic example is putting a pinhole in a styrofoam cup when it's being filled from a garden hose...
Thats not bad at actually. But then how much more beneficial is the JDM rear bumper with a diffuser, how does it displace the air that is coming trough to the back downwards so it doesn't get stuck in the back of the bumper.
