I need help, subaru
Old Apr 20, 2009 | 09:26 AM
juanmedina's Avatar
UPDATE
I went to the 1/8 again last friday (the 1/4 had something going on ) and I did a little better. I only got 2 runs with a 5 hr wait
First run
60' 1.746
330' 4.948
1/8 7.545
@ 94.158 MPH
First run
60' 1.845 (major bog RPMs drop all the way down to 2.5k
330' 5.250
1/8 7.942
@ 89.804 MPH
So I am wondering if I can cut a 1.65 60' that will be about 7.3-7.4 on the 1/8, correct? and that will put me on mid 11s and maybe a little lower , correct?
with 300whp
I can't wait to go to the 1/4
VIDEO
Old Apr 20, 2009 | 09:39 AM
InfiniteMotors's Avatar
Also consider your shift points. Where are you shifting in each gear? With a VF39 on a 2.5 you should only see redline as you cross the line. Dyno chart?
Old Apr 20, 2009 | 09:41 AM
bbyevo8u's Avatar
Originally Posted by juanmedina
Yes they are heavy 21lbs 18x9.5 rota grids, 245/40/18 nexen 3000 tires
The times are with a protuner map E85 at 22.5psi with COBB AP, after AP. Keep in mind that I am making about 330whp max on a dyno. With airboys interpolation sheet I am making 295whp and like 320wtq
My tranny just broke and got something almost indestructible, so I can launch hard as long as I don't break my axels . On those runs I launched at 4.5K rpm, I am going to lower my tire pressure and launch maybe at 5.5K, I got a forged LSD so maybe I just drop my clutch
omg your small turbo is pushing 22.5 psi it must be choking at top end from being out of breath, i had my 06 sti running 18psi and it felt maxed out.. good job tho
what tran's did you go with?? tre - shep
Old Apr 20, 2009 | 09:51 AM
juanmedina's Avatar
I have no idea at what RPMs I was shifting the sun was in my face , all I know is that I have to shift at 6K, I have a road dyno chart I will post the sheet when I get home. I am making 305whp and 330wtq on E85
DS1 motorsports tranny, my tunner and I are going to push it to 25psi .
Right now I am hitting 22.7psi max and it drops to 15.5psi at redline .
So we are going to raise the boost and add a helper spring, I can't wait
Old Apr 20, 2009 | 11:08 AM
bbyevo8u's Avatar
why don't you just put a new turbo in there?? oh thats right you want to set the record first then the new turbo lol good luck with setting a new record!!
Old Apr 20, 2009 | 06:57 PM
C130flyer's Avatar
if you can't "find evidence that NLTS improves ET" then you don't know anything about drag racing and need to quit. You are never going to run the full potential of "ANY" car without doing this!!!!!!!!!!!!!!!
Old Apr 20, 2009 | 07:04 PM
jaycheetwood's Avatar
Just the fastest VF39, my car looks stock you need glasses my friend
VF39 and STI TMIC
Perrin Headers and Uppipe (ceramic coated)
Buschur TBE (ceramic coated) BUSCHUR POWER
Hallman MBC
APS intake
Gimmick turbo inlet
TGV deletes
Phenolic Spacers
APS dual vent BOV
Also I am running 22.7 psi making 293whp and 320wtq on Airboy dyno road, I can raise it to 25 psi but I need a new spring, I will run it as it is and see what happens. After that I will raise it to 25 psi and use a EWG to hold boost better
I know that was the first time at the track for me ever, I am really happy with my 60' after looking around in both forums most noobs are lucky to get 2.0
I have a ACT HD clutch and build tranny now, so I am tempted to just drop the clutch. I am planning on Launching at 5.5k with a 23lb tire pressure, on the video I launched at 4.5k
Your only making 293 whp? With all that?
Old Apr 20, 2009 | 07:12 PM
JuniorAWD's Avatar
No moon dyno.. Besides he backed up that 29X-305whp with a 95@1/8th...
Some like big numbers on a dyno, others like them on time slips.
Old Apr 20, 2009 | 07:15 PM
Just seemed like it would be higher to get that kinda of time.
Old Apr 20, 2009 | 07:55 PM
juanmedina's Avatar
What are you talking about willis?, I know NLTS or FFS works on big turbo cars, but my turbo is tiny, smaller than the stock EVO VIII 16G .
I tried NLTS on the second run even with the bog my trap suffer 89mph is my lower trap ever, my tuner is working to fix my NLTS but for some reason my car doesn't like it. Anyways I think I will get the record lift shifting
I got 305whp 2 days before going to the track.
Crom
Aug 16, 2016 05:43 PM
9sec9
Jul 28, 2009 07:08 PM
Most-Wanted
May 17, 2008 08:55 PM
RyuEvoIX
Apr 17, 2008 05:18 PM
NIevo
Apr 12, 2008 12:40 PM
