HTA86 Twinscroll Track Results
So After bolting on the twinscroll T4 to my car, I figured might as well give it a try at the track.
Here is some background info:
https://www.evolutionm.net/forums/ev...k-results.html
Current Mod list
HTA86 w\1.00 AR T4TS
APS 3inch Complete Exhaust
BF 272 Cams
AEM EMS 1200cc inj
Driven Innovation Intake w\75mm TB
1mm Oversized TurboTrix Cylinder Head
2.0 liter TurboTrix Built
HKS DLII Ignition
Buschur Race FMIC with THE SHOP ICP
Pump Gas w/ 29 PSI
With a 1.8 60ft it ended up with a 10.8 @ 135!!
Again Huge Thanks To Jimmy and Junior for making this happen!
Of Course for the 3rd straight different track in a row, I was told I need a Roll cage, Fire Jacket, actually a Rule Book..
Current Mod list
BF 272 Cams
AEM EMS 1200cc inj
HKS DLII Ignition
Pump Gas w/ 29 PSI
Thanks guys! 40 plus PSI Next time.. but I have to wait till a track rental.. they are a little more "friendly" about not having all the proper safety equipment. If low boost/pump gas is getting me kicked out.. Not sure what 10+ PSI and a **** load more timing is gonna do..
This was in Dirty Jersey, not NED lol
10.8 on pump gas with a 1.8 60 ft? Nice job man that is awesome.
Hell if you cut a 1.5 60 ft you'd probably run a 10.2 or so. Dave Buschur had to step up to a slightly bigger turbo than a 35R if I recall to get into the 9's on pump. So basically it seems your making the same power as Dave's RS on pump?
It depends on a lot of factors. Larger turbos are more efficient at 30 psi than smaller turbos, therefore the charge temps are lower. Also, larger turbos normally mean larger headers and turbine housings, this means less back pressure, which also can help fight detonation. Plus many other factors. Basically there is no rule of thumb that says X amount of boost pressure for Y amount of octane. Every car/setup is different.
