Stock evo 8 1/4 mile
Old Jun 28, 2009 | 03:12 PM
theboricua's Avatar
Som i decide to take my vehicle to the drag strip to see what it can do, the vehicle is stock other than a drop in filter, and my numbers seem high, is this stock numbers? .... elevation sea lvl 96 degrees with 20% humidity.
R/T .362
60' 2.042
330 5.913
1/8 9.161
mph 77.53
1000 11.954
1/4 14.2
MPH 97.40
Old Jun 28, 2009 | 03:14 PM
DSMorBUST's Avatar
you need a driver mod.
Old Jun 28, 2009 | 03:19 PM
theboricua's Avatar
Hehe your probably right...I just didnt want to break anything I wasnt dropping the clutch I was launching by letting it go slowly.
Old Jun 28, 2009 | 06:25 PM
wtmodnar's Avatar
you're suppose to let it go slowly, but to slow u burn the clutch , I learned the hard way, but I got better. Keep at it and try to get those 1.7-1.8 60's
Old Jun 28, 2009 | 06:31 PM
kanyonkid's Avatar
the fastest i pulled my stock evo was 13.4.... get that launch down
Old Jun 29, 2009 | 10:13 AM
awdwannabe's Avatar
You've got a little way to go.. The driver mod. is the best free mod. there is.
I took my '05 to the track for the very first time, with the same mods. as you and pulled of a 12.95 @ 106.32
Old Jun 29, 2009 | 12:28 PM
mrdevo's Avatar
That sounds about right. The heat and poor launch definitely affected the run. That's what I'd expect actually. Play with your shift points too, there might be some room with that.
Old Jun 30, 2009 | 09:07 PM
tlcoll1's Avatar
Your car definitely seems down on power, since even with improved 60' you'll be under 100 MPH in the traps. It was hot - did you do any data logs? Would be good to see if the car is mistuned and knocking.
Old Jul 1, 2009 | 09:03 PM
C6C6CH3vo's Avatar
Stock 03 and 04's are slooow. I know from experience. Keep the intake temps down, let it breath, and add boost you can easily remove a couple seconds with a good run
Fourdoor
Dec 18, 2011 07:36 PM
Fourdoor
Oct 25, 2009 06:31 PM
partyboy1122
Apr 12, 2009 07:17 PM
MikeSactown
Aug 30, 2008 08:27 AM
ZeroFrost
Mar 29, 2004 01:14 AM
