motorcycle slick
The rx7 wheels are very light I think they are about 13lbs. The tires on them are about 4 years old. The track I go to does no prep at all, it gets low 1.5 60ft's all the time, im sure if the tires are new it would cut 1.4's. It drives mint on on them, its still a DOT tire. The fastest it went is 10.33 @137 and it went 115mph in the 1/8, the car should go 9's. The car has never seen the dyno, one day Ill go and see whats up.
For the wheels I use 20mm spacers with arp extended studs just in the front. Its very very close to the brakes.
Which QTP you running?
This?
#17430
26 X 9.50-16 LT D 8.0" 26.1" 82.0" 6-8" 8" 9.3" Quick Time Pro
what tire pressure you running with it?
This?
#17430
I was told not to run spacers and extended studs. I don't know why?
We prob have same or close WHP on my pump gas tune. I hope it fits because I don't have coilovers just Tanabe GF210 right now.
Where is the cheapest place to buy this QTP?
By the way i brought this up over a year ago but no responses
https://www.evolutionm.net/forums/5740980-post9.html
Now i know thanks Raif
SS1000RR
Dec 9, 2015 01:58 PM
555R
Sep 7, 2014 10:14 AM
BR350VIII004
Jan 27, 2012 07:18 PM
