motorcycle slick
Old Jul 24, 2009 | 05:48 PM
mystoticracing1's Avatar
motorcycle slick
hey guys i tried searching cant find anything. im trying to get tires that really grab. i have nitto 555 but the are doodooooo. im making 608 on pump. im running 11.137 at 129 but just cant get grip for nuttin and was getting valve float. valve springs are getting done right now but i need tires. i heard there is a motorcycle slick that will fit on a 17in rim. i have enkei rpf1's.
Old Jul 26, 2009 | 10:51 AM
dambikeracer's Avatar
Wait a month for the Hoosier 245/45/17 Drag Radials. The motorcycle slick is only 7" wide. The 245/45/17's are 9.7" wide and will work well with a 8-8.5" rim. To run the motorcycle slick you should run a 7" rim. The only rim that will clear our brakes are Indy Performance 4258's. Hope this helps.
http://www.indyperformance.com/
Old Jul 29, 2009 | 07:35 AM
not_nyce06's Avatar
those rims are ugly!!
Old Jul 29, 2009 | 06:04 PM
Raif's Avatar
you can run the Hoosiers QTP with RX7 wheels 16" and stock brakes. You will need spacers to make them fit. They work very well.
Old Jul 31, 2009 | 11:54 PM
evovin's Avatar
got pics?
Old Aug 2, 2009 | 09:30 AM
Raif's Avatar
Old Aug 2, 2009 | 10:04 AM
4g63evoeight's Avatar
car looks good Raif. you goin to LVD this wed? i'm gonna shoot for a 12.8-12.99 bone stock.
btw, its Peter with the Red RS. Rubins friend.
Old Aug 2, 2009 | 10:30 AM
Raif's Avatar
thanks man. Ill be up there as long as the track is still not under water. You should be able to run 12.80s no problem, just drive it hard.
Old Aug 2, 2009 | 10:35 AM
yea we'll see. oh i'm going to send you a pm in a minute.
Old Aug 2, 2009 | 11:11 AM
kouzman's Avatar
this is very nice man!!!! i knew that those wheel will fit! LOL
can you give me more info on the spacers, lugnuts that you used? have you race the car yet with this combo yet? how does it feel?
Old Aug 2, 2009 | 11:21 AM
Jeovannie's Avatar
and you can get them cheap
http://cgi.ebay.com/ebaymotors/Set-o...Q5fAccessories
Old Aug 2, 2009 | 11:45 AM
evovin's Avatar
+ 1
what's the best 60ft and trap you made so far with this combo?
That rx-7 rims looks heavy. Or mybe not
Old Aug 2, 2009 | 11:50 AM
Jeovannie's Avatar
according to them http://www.wheelweights.net/ they are 15.4
but you know how accurate is the internet
Old Aug 2, 2009 | 12:56 PM
Raif's Avatar
The rx7 wheels are very light I think they are about 13lbs. The tires on them are about 4 years old. The track I go to does no prep at all, it gets low 1.5 60ft's all the time, im sure if the tires are new it would cut 1.4's. It drives mint on on them, its still a DOT tire. The fastest it went is 10.33 @137 and it went 115mph in the 1/8, the car should go 9's. The car has never seen the dyno, one day Ill go and see whats up.
For the wheels I use 20mm spacers with arp extended studs just in the front. Its very very close to the brakes.
Old Aug 2, 2009 | 01:20 PM
xRoguex's Avatar
nvm-- stock evo 20.5
