368whp=12.9!Help!
368whp=12.9!Help!
hello..
B4 I added cams and fuel pump and a retune I managed to run 12.9 with 312whp..now wth 368whp I cannot get lower than 12.9!
Im getting the ACT high rpm clutch lockout..Im launching the car @5k and no matter how I drive this is the best time I have reached..
Any Advice On how to improve my 1/4??
The best 60was 1.78
constant 1.8
@104mph!
The best 60was 1.78
constant 1.8
@104mph!
More info needed....
Your 60 ft while not great is not terrible. What did you trap ? Speed @ 1/4 mile ? If you def are getting lock-out that will slow your shifts, where is lock-out occurring 3-4 or ?
Might could be your 7 turbo is running out of steam...could be lots of issues. You don't seem to have big fmic, so the ambient (summer) temps would in it'self effect your timeslips
Post up some more info.....
1/8
and trap
1/8
and trap
craziest thing..I was stuck at 12.9 with a lot of power myself in my subie..but it's a subie with a stock turbo; so I just chopped it to needing more hp
my best trap was 106, which sometimes net's guys 12.6-12.7
you might have a MASSIVE boost leak somewhere, i can almost garrantee it.
you and i are making almost identical power, yet two days ago my car felt like utter dog ****.....i had a HUGE boost leak on one of my couplers, one of my clamps had given out.
howd i make the power then when i was getting tuned? the asnwer i also was able to figure out.
i was able to pull super hard in any *1* gear(which is why your probably tuned correctly), however when i shifted my car felt terrible, the coupler would leak badly with all the engine movement.
check all your joints, and pressure check the entire system. this will show you were your leaks are and what pressure your BOV starts leaking.
even with me bogging my launch missing second and fourth i was able to pump out a 12.7 @ 106
