Buschur Racing/IDRC Sport Compact Nationals
Saturday, May 29th, 9am to 5pm.
Buschur Racing Inc., in Wakeman, Ohio. We will have a dyno competition and open house. The dyno competition is $50/3 pulls, there will be a first place trophy awarded for highest 2wd and AWD vehicles. Cars that are too low to clear the dyno will not be loaded. NO NITROUS ALLOWED ON DYNO. Bottle must be removed from car.
IDRC will be involved in the event this year and we have added two more classes, True Street and the 8 Second Street Car Challenge!!
Sunday, May 30th, 9am to 5 pm. Summit Motorsports Park, in Norwalk, Ohio. Time trials from 9am-12 pm. First round of eliminations at 1 pm.
PRESENTED BY:
Buschur Racing, IDRC, DSport Magazine, Harlow Specialty Tires, Dynoflash, AWD Motorsports and Shearer Fabrication
Car and driver, $35.
Quick Class, $200
Specatators, $15
Kids 12 and under are free.
The event on Sunday is open to ANY FWD, RWD or AWD. The event is open to any 4 cylinder, 6 cylinder or rotary powered vehicle. All race classes are trophy classes with the exception of the Quick Class/8 Second Street Car Challenge and True Street classes. The use of delay boxes and throttle stops are prohibited. Trans brakes are OK.
RACE CAR CLASSES:
IDRC TRUE STREET CLASS
True Street Turbo RWD/AWD Class
Looking for “real” street performance? Check out the IDRC True Street Class.
With all cars running on D.O.T. radial tires, through the mufflers and in “street legal”
trim, the IDRC gives the local “Kings of the Street” a chance to become national heroes.
All vehicles in this class maintain the factory chassis construction. A minimum
class qualifying time of 13.99 must be met to make the qualifying field.
For fair and entertaining competition, the True Street class (along with all IDRC
heads-up classes) runs a .400 Pro-Tree. Cars pair up according to a “Sportsman ladder”
for eliminations. The competitor with the quickest elapsed time from the previous round
will have lane choice for the following round. All events are run in single-elimination
fashion. Red-light false starts will result in automatic disqualification as does crossing the
centerline.
Fields will be made up of the eight quickest competitors from the qualifying
rounds. No make-up runs will be permitted for racers that miss their qualifying round. If
a qualifier elects not to compete or is unable to make the last call to the staging lanes, the
next available alternate will be selected until a full field of eight is present, whenever
time permits.
Class Specifications
Eligibility
All vehicles must pay racer entry fee. All True Street Class drivers must be
IDRC members. Those electing to race without membership will have a full-price $45
membership fee deducted from their winnings per event. The racer on the tech card for
the vehicle must also be the driver. Additional drivers will pay full race entry fee and
must notify officials that there will be two drivers. The driver that qualifies vehicle must
also be the driver in elimination rounds. All True Street class vehicles must pass the
safety tech inspection issued by the track. Most tracks follow NHRA or IHRA safety
regulations. The safety inspection is separate from the IDRC classification. The
classification will precede or follow the tech inspection. Vehicles will only be eligible
after passing safety inspection and being classified as eligible True Street class vehicles.
It is the driver’s responsibility to make sure vehicle meets weight requirements. Vehicles
will be weighed after each qualifying and elimination round.
Registration
All True Street class cars must be currently DOT registered, have valid insurance
or possess an IDRC “True Street Class Certified” decal. Decals will only be issued to
vehicles passing an official IDRC inspection and certification (cost $100). This policy
was adopted since many states have differing smog inspections and device requirements.
The IDRC “True Street Class Certified” inspection will check the operation of
headlights, signals, driver and front passenger windows. If the vehicle is operational in
these categories and is legal for classification with other class requirements, a decal will
be issued after inspection. This decal is valid for a period of two years from the date of
issue.
Engine
Only one internal-combustion gasoline engine permitted in vehicle. All watercooled
engine blocks must be production based with a production run exceeding 500
units. Cast aftermarket cylinder heads are permitted for all vehicles. If a water-cooled
engine’s cooling system is utilized, these engines are required to run only water. No antifreeze
is permitted. Engine manufacturer must match vehicle chassis manufacturer.
Brother-company substitutions are allowed, such as Lexus/Toyota, Nissan/Infiniti,
Honda/Acura. Domestic manufactured engines (Ford, GM, Chrysler) are limited to fourcylinders
and OHC six cylinders. Engine must be located and configured in OEM
location. Setting engine forward or back is allowable when and only when modified
engine mounts attach to factory mounts on the frame or cross-member assembly.
Changing engine from transverse configuration (East-to-West) to conventional (North-to-
South) is not allowed. Engine type (# of cylinders) and the number of power adders will
establish minimum weight breaks along with drive configuration (FWD, RWD, AWD).
Engine Maximum Displacements
Engines are not to exceed the following displacements based on the engine’s
number of cylinders:
4 cylinders less than 2850cc
5 cylinders less than 3563cc
6 cylinders less than 4275cc
8 cylinders less than 5700cc
Racers wishing to challenge the displacement of another competitor’s engine will
post a $250 protest fee. The IDRC will conduct a P&G test to determine the displacement
of the engine. If the engine exceeds the maximum displacement allowed, the racer will be
barred from competition at that event and all event points will be forfeited. The protest
fee will then be returned to the racer filing the protest. If the racer’s engine is of a legal
displacement, the protest fee will be kept by the IDRC.
Oil Downs & Coolant
Racers must always pull over to the wall immediately when breakage occurs.
Failure to do so often results in oil, water or coolant being left on the racing surface. This
results in many minutes of down time.
Power Adders
Engines may be equipped with up to two power adders. Power adders include
nitrous-oxide-injection systems, turbocharger systems and supercharger systems.
Redundant power adders such as twin-turbochargers or multi-stage nitrous-oxide systems
count as a single power adder. Thus, a twin-turbo engine using a three-stage nitrous
system would still count as only two power adders.
Intercooler must be air to air only. Intercoolers, cool cans for fuel systems and
compressed nitrogen gas systems used to cool the intercooler are not counted as power
adders. Any compressed gas used on the vehicle is subject to inspection. If the
compressed gas is found to be an oxidizer (like nitrous oxide), it will be counted as a
power adder and appropriate weight requirements will apply.
Exhaust
All True Street class vehicles must run an exhaust system that exits behind the
rear wheels.
Fuel
Fuel cells prohibited. All vehicles must run on gasoline. Pump and racing
gasoline are acceptable. Gasoline may not have nitro-methane, propylene oxide or nitropropane
added. All fuels are subject to testing by IDRC officials. For 2002, the IDRC
may institute “spec” fuels (one leaded and one unleaded for the Street Class). A decision
or ruling on this can be found at www.importdrag.com or by calling the IDRC office. If a
spec fuel is established it will be required for competition as long as the fuel is available
at the track. The spec fuel’s manufacturer or the IDRC staff will perform fuel checks on
the competitors.
Interior
Mandatory for vehicles to have dash board, 2 front seats and door panels.
Transmissions-RWD/AWD
Transmission must match manufacture of engine. Standard transmission must
retain factory H-pattern. All non-OEM transmissions are prohibited.
Chassis-All Basic
All True Street Class vehicles must use an import chassis with functional doors,
barring the following exceptions: Exceptions will be made for domestic-labeled, jointmanufactured
vehicles that have a USA-available, import counterpart. Examples include
but are not limited to: Chrysler Conquest, Dodge Colt, Dodge Stealth, Eagle Talon, Ford
Probe; Mercury Capri XR2, and Plymouth Laser. Additionally, any front-wheel-drive
vehicle from any manufacturer (including Domestics---Chevy, Chrysler, Ford) is legal
for competition.
All Street class vehicles must retain factory chassis. Vehicles originally built with
a front-wheel drive configuration must maintain front-wheel-drive configuration. Chop
tops are permitted.
Glass
All Street Class vehicles must maintain the factory glass.
Suspension & Chassis-RWD/AWD
REAR
Retention of the OEM rear-end assembly is mandatory. Back-half conversions
and tube chassis configurations are not permitted. Full wheel tubs are not permitted.
Solid-axle rear conversions are permitted. Strut tower braces, lower tie bars, sway bars
and limit straps are permitted. Rear suspension must maintain a minimum of one inch of
travel. All rear suspensions must use at least one hydraulic shock per wheel.
FRONT
The entire reinforced portion of the factory front shock tower member (this would
include the entire portion that is welded to the uni-body frame) must be retained. Roll bar
may attach and strengthen the shock-tower member. Upper mounting point for strut
assemblies must be in factory location. Top of strut assembly must mount to top of
strut/shock tower, as did the factory unit. Adjustable caster/camber pillow-ball mounts
are acceptable. Lower control arms may be strengthened and altered providing that
factory mounting at frame is not changed in location. Lower mounting point for strut may
be modified for improved caster or camber. Strut tower braces, lower tie bars, sway bars
Professionalism
All vehicles in True Street Class competition are required to have paint and an
outward appearance that is at least of OEM quality. No bodywork, primer or unpainted
body kits will be permitted. Failure to adhere to this ruling will result in a warning at the
first event. This vehicle will be barred from future competitions until the appearance of
the vehicle meets the requirements.
All vehicles are required to have die-cut issued competition numbers in the
correct location as indicated by the individual event’s racer information packet. The use
of shoe polish or liquid chalk is restricted to the IDRC officials for classification.
All crew members are required to be in uniform is accompanying the competition
vehicle to the burnout and staging areas. Uniforms can be as simple as matched T-shirts
and jeans. Consistency and cleanliness is the objective.
Tires
All True Street class vehicles must use D.O.T. radial tires. Skinnies are
prohibited. Metric-specified tires may not exceed a section designation of 315. All other
tires must measure less than 10.5-inches in tread width, not in section width. Maximum
tire height is 28 inches. No slicks allowed.
Wheelie Bars
No wheelie bars allowed.
Performance
A minimum class qualifying time of 13.99 must be met to make the qualifying
field.
8 SECOND STREET CAR CHALLENGE
-New for this year the 8 Second Street Car Challenge.
-This class will be open to any and all 4 cylinder, 6 cylinder and rotorary street cars.
-DOT tire ONLY. Full exhaust exiting the rear of the car. Full interior including, door panels, dash, front and rear seats unless the rear seats interfer with a roll bar, carpeting, center counsole if equipped, working headlights, wipers, all side windows must roll or be powered up and down and rear view mirrors. Front of the car must be open to allow air to the radiator for actual street use. This is a class for true street cars.
-The class will be run at 10 am, 12 pm, 2 pm and 4 pm.
-$1,000 to the car going in the 8's in true street form on a DOT approved tire. In the event of multiple cars breaking into the 8's the lowest ET will take the prize money.
-Harlow Specialty Tire and Wheel has posted $100 to the winner and $50 to the runner up. You must buy your tires from Harlow, have your receipt and win on the tires you won.
RFD-This is for Front wheel and Rear wheel drive vehicles. DOT tire only. Full exhaust required. Heads up/pro tree class.
RFS-This is for Front wheel and Rear wheel drive vehicles. SLICK tire only.
Open exhaust is OK. Heads up/pro tree class.
MD-This is for All Motor vehicles only. NO POWER ADDERS allowed. DOT tire only. Full exhaust is required. Heads up/pro tree class.
MS-This is for All Motor vehicles only. NO POWER ADDERS allowed. SLICK tire only. Open exhaust is OK. Heads up/pro tree class.
AWD-This is for All Wheel Drive vehicles only. DOT tire only. Full exhaust is required. Head up/pro tree class.
AWS-This is for All Wheel Drive vehicles only. SLICK tire only. Open exhaust is OK. Heads up/pro tree class.
B1-Anything goes. 0-12.99 dial-ins. Handicapped start, bracket racing.
B2-Anything goes. 13.00 and slower dial-ins. Handicapped start, bracket racing.
QUICK CLASS-Qualifying for Quick Class will be at 10am, 11 am and 12 pm. If you qualify for Quick and make the field you must run Quick. If you attempt to qualify and do not make the field you can enter any of the other classes that your car fits in.
**This class requires a $200 entry fee paid at the gate upon entry to the track. 100% of the entry fee for this class will be paid out to the racers in the class.
With a full field that will be a total payout of $3200.
1st place, $1800
2nd place, $900
3rd place, $250 each
In the event of a field of less than 16 cars or more the percentage will be based on the above payout.
Awards/payouts will be available at the end of racing at the customer service building.
VENDOR SPACE. Please send a PM to David Buschur here on the forums.
CLASS SPONSORS. If you are interested in sponsoring one of the classes please contact me via PM.
PRESENTED BY:
Quick Class, $200
Specatators, $15
RACE CAR CLASSES:
centerline.
time permits.
Eligibility
Registration
issue.
Engine
Oil Downs & Coolant
Power Adders
Exhaust
rear wheels.
Fuel
the competitors.
Interior
Chassis-All Basic
for competition.
tops are permitted.
Glass
REAR
FRONT
Professionalism
Tires
Wheelie Bars
Performance
field.
1st place, $1800
2nd place, $900
Very excited about this years event! As you can see we've teamed up with the IDRC to bring in the True Street Class.
With my drive to put my RS into the 8's on DOT street tires and Mike Ferrara's goal to do the same with his Skyline GTR we have put together the 8 Second Street Car Challenge. Buschur Racing has put up $1,000 to the car that goes deepest in the 8's the day of the race and meets the rules. Harlow Tire has put up $100 to the winner $50 to the runner up, also meeting the rules.
We are currently working on other tire sponsors for that portion of the event.
Last years event grew substantially and with the addition of IDRC and the 8 Second Street Car Challenge for this year I expect it to grow by a large amount.
Feel free to cut and paste the first post onto your other forums, I'd appreciate it actually.
Thanks for reading and hope to see a lot of EVO's there!
Good to hear you've hooked up w/ the DSport people we need to bring Import Racing back to the fore-front.................................or at least a bit more coverage since it seems that the AWD/TURBO cars have brought a bit of a revival to our recently DEAD sport...........hope that means good things for the future
Sounds like a blast Dave! I will try to put this on my calendar, rent a trailer, and come down with the new snky with Emery and the gang! It would be good to finally meet all of you guys in person.
--mark
--mark
David Buschur
May 28, 2013 06:35 AM
David Buschur
Jun 1, 2011 06:35 PM
