What are the options for drag slick setup and stock brakes
Old May 17, 2010 | 07:56 AM
joel(PA)'s Avatar
I see a lot of people are switching to smaller front brakes to get slicks on the car.
are there any other options other than running motorcycle tires and running stock wheels or other 17" wheel variant?
Old May 17, 2010 | 12:51 PM
rong.'s Avatar
Drag Radials
You can use stock 17 inch rim and run drag radials. You don't have to run small brakes and slicks to go fast.
Old May 17, 2010 | 02:18 PM
joel(PA)'s Avatar
i just bought a set of FD rx7 wheels and hoosier QTP's and a ichiba 20mm V2 spacer set. Should be all setup! I'll post some pics once installed
Joel
Old May 17, 2010 | 02:36 PM
RiversideMitsu's Avatar
Joel
Thats what I purchased prior to going to with the AMS Wilwood brake kit and 15inch slicks. You wont be disappointed with that setup.
Old May 18, 2010 | 06:19 AM
FL_SilverEvo8's Avatar
I think the smallest rim you can go with on the stock break set up is a 16" rim. Depending on the offset you might need spacers to clear the breaks. It prob wouldn't hurt to get extended wheel studs and the right lug nuts just to be on the safe side.
Old May 18, 2010 | 08:31 AM
Spoolin20v's Avatar
it goes hand in hand. if you space it, get longer studs
Old May 18, 2010 | 04:23 PM
raiceboi697's Avatar
smaller rims equal to less rotational mass which means more power transferred to the ground and less weight you have to move. thats why most people put there cars on a diet to aid in going fast
Old May 18, 2010 | 05:09 PM
Svendiesel's Avatar
9sec9.com's Hoosier 245/45-17 slicks, perfect tire for a stock rim. Nasty good tires too at that. Im highly considering picking a setup soon. Theyve pulled 1.4X 60ft times.
Old May 18, 2010 | 08:06 PM
joel(PA)'s Avatar
radials are hard on the drivetrain... not enough sidewall flex
Old May 18, 2010 | 08:15 PM
Macaroni's Avatar
I'm eventually gonna go with the stock rx7 wheels and the Hoosier QTP's as well as soon as the money fairy pays me a visit...
Old May 18, 2010 | 11:57 PM
omniprobe's Avatar
I heard they had softer sidewalls than most people think.
Old May 19, 2010 | 05:32 AM
joel(PA)'s Avatar
they are softer than most street tires, yeah, but there is nothing that is quite like an ET Street or Hoosier QTP
Old May 19, 2010 | 07:59 AM
With drag radials less to no wheel hop is what we need. You start having wheel hop you start breaking stuff. right?
Old May 19, 2010 | 08:00 AM
EvoDan2004's Avatar
basically
Old May 19, 2010 | 08:05 AM
here this is what mike @awdmotorsport said in the post about the event he went to this pasted weekend.
Originally Posted by Mike@AwdMotorsports
Using 16psi.. The car tire hopped on Sunday and broke the hollow shaft in the trans.. The problem with stiff sidewall tires like these Hoosiers.. Eventually they will get you..
Mike
