What are the options for drag slick setup and stock brakes
Old May 19, 2010 | 08:09 AM
Macaroni's Avatar
Is he talking about the QTP's?
Old May 19, 2010 | 08:12 AM
gamebred26's Avatar
Originally Posted by joel(PA)
i just bought a set of FD rx7 wheels and hoosier QTP's and a ichiba 20mm V2 spacer set. Should be all setup! I'll post some pics once installed
Joel
so you are going to rock a 20mm spacer when you take the slicks off and run your regular street tire rim?
or you going to take them off every time...that would suck ***...
Old May 19, 2010 | 08:32 AM
Macaroni's Avatar
Spacers aren't that hard to take off...
Old May 19, 2010 | 10:28 AM
Draven83's Avatar
spacers just slide on and off so when you switch tires its a extra 30seconds.
Old May 19, 2010 | 11:21 AM
gamebred26's Avatar
not 20mm spaces they bolt on to your studs....so in essence you have to do 10 bolts instead of 5 if you are changing **** at the track...each side...
or i guess you could rock a 20mm at all 4 corners and leave them on...
its almost a full inch with and without...so i dont know why you would put one in front with the slicks and not want the slicks in the rear to be at the same distance from the hub...
or if it would affect the launch keeping the car straight is a ***** as it is in awd on a slick ...i would imagine having your rears at a diff offset ie narrower would affect it...
or maybe not...idk
rodent
May 19, 2016 07:51 AM
GGevo921
Oct 12, 2011 10:09 PM
ScoobyDoo8
16
May 27, 2010 10:12 PM
redevo58
Jun 30, 2009 07:23 PM
Shacochis06
Feb 13, 2009 03:56 PM
