E85 stock turbo times
Old May 31, 2010 | 07:21 AM
PlanoEvo's Avatar
Please post up your times for those on E85 and the stock turbo whether it is an VIII or IX and what supporting mods as well thanks
Old May 31, 2010 | 11:53 AM
neonglh's Avatar
Just look at the stock turbo times for 2010...
Old May 31, 2010 | 05:15 PM
PlanoEvo's Avatar
damn near everyone on that list has a modified stock frame I was more after the stock VIII and IX since my IX recently switched to E85 and haven't had the time to get to the track yet just curious.
Old May 31, 2010 | 05:51 PM
BGevoIX's Avatar
A lot of guys here in Norcal are running mid to high 11s on the stock turbo and E85. Most are still full weight street cars on street tires as well. And most of them are running around 27-28psi. Nothing in the 30+ psi range on the stock turbo that I'm aware of.
Old May 31, 2010 | 08:19 PM
slow/ass/rs's Avatar
1st time out went 11.5 at 120 consistently with some issues 2nd time out 11.38 120 best (i got kicked out)
FP4R cams
RC 1200cc injectors
255 fuel pump
Titek 02 housing
GST eleventy billion open air filter in hacked OEM airbox
LICP
3" turbo back exhaust but with a 2.75 down pipe
GM 3port boost solenoid using ECU-controlled boost
and good old E85!!!!
street tires 300+lbs diver and stock evo 9 gearing
pic of the engine bay
Old May 31, 2010 | 10:16 PM
PlanoEvo's Avatar
FP4R cams
RC 1200cc injectors
255 fuel pump
Titek 02 housing
LICP
Talk About a sleeper engine bay pic mine looks almost the same except for the COP, I'm using a perrin drop in.
I have a very similar setup with FP4R's except FIC 1050s,Spoolinup COP,ETS 4in IC, MBC but no O2 housing and 130lbs weight reduction I'm 170 So I'm guessing with a good launch we would have similar times. I'm running 29lbs what are you running?
Old Jun 1, 2010 | 12:20 AM
ant_turbo's Avatar
11,8@114 stock turbo evo 9//// stock block
Old Jun 1, 2010 | 01:18 PM
awddyno's Avatar
look in the stock turbo section not the stock appearing.
My car went 10.88 @123.9
Stock engine, stock turbo, TBE, intake, FMIC and pipes. E85
Old Jun 2, 2010 | 05:43 AM
Turbojunkie's Avatar
slow/***/rs...
Where is that 10 sec pass you promised me a couple months ago. Im all most their. 11.097. how much closer are you.
Old Jun 2, 2010 | 10:22 AM
awddyno's Avatar
Who you calling slow *** rs? haha.
Old Jun 2, 2010 | 11:18 AM
dsmfan95's Avatar
Probably the guy named slow/***/rs
Old Jun 2, 2010 | 11:42 AM
PATRICK B.'s Avatar
Originally Posted by Turbojunkie
slow/***/rs...
Where is that 10 sec pass you promised me a couple months ago. Im all most their. 11.05. how much closer are you.
AFAIK I don't think his car is back up and running yet
Old Jun 2, 2010 | 02:14 PM
Hopefully he is putting the stock turbo back on. He promised to be in the 10's...... deep in the 10's on the stocker. That is why i was giving him a hard time.
Old Jun 8, 2010 | 12:33 AM
29 to 30psi
Old Jun 8, 2010 | 12:40 AM
it will be up sooner or later so when i go out and run these times i claim im going to run then what are you going to say???...its all fun a games
