Evodan2004 new pump gas record 10.50 135.56
That's consistent man. I bet that if you loose like 200-300lbs with the usual parts, borrow some bfg's and pull of a lower 1.5, no lift shift, you might pull of 9's on pump with this power level. Very impressive considering your torque, response and spool.
But you know how I feel and I wouldn't risk a bad tank of gas(kaboom), or a bad launch and destroyed drive line and transfer case etc. I would rather blow up going for 150+ traps on E85 to shut up all the upper RPM Twin Scroll doubters like mysefl
I'm rooting for you.
I'm rooting for you.Mike
this is my own records ''personal''. i could care less if its a world record nore am i hunting for one. if its a world record then its because its a yellow car on a fri night at 914pm with ace of base playing at the start line and the visor up on my helmet. there. now i hold a world record.
i posted my time slips.
here is a vid. ****ty but its a vid. next time im racing in the left lane and not the right. that should help some when watching.
http://www.youtube.com/watch?v=9D0iP_CaHA4
tire PSI on this run i think was 20 psi. my 1.63 and 1.59 was 22psi. but i didnt run those runs out.
Its all in the left foot. also check you tire psi after a couple runs because the pressure will go up
Use your logic backwards... Offer $500 to anyone that can match the low/mid power and response of a T3/T4 1.06 Twinscroll turbo with a T3/T4 1.06 single scroll turbo - either way your money is safe...
That's not a fair comparison Mike. His car is full weight with AC etc etc. That's why I said 150 with his T4 TS HTA86. Think more like the T3 cars from the Buschur 3 amigos, that would be more fair IMO even though the 3 amigos probably have more in their cars, but maybe not. Either way if Dan can trap with those guys and put up his chart comparing his spool to theirs the debate is over IMHO. But that's a lot of ifs and with many years waiting we still haven't seen the aforementioned with one of Geoffs customers.
i do not have A/C. i dont like it i never used it. its removed only for the fact of my DP. other wise the car has everything from power windows to working tail lights.
