First time at the drag strip...ugly slip inside...help brake it down
Old Nov 14, 2010 | 09:36 PM
dtrackstar's Avatar
So decided to take the evo to the track before I put it away for winter. It was my first time. I know my 60 foot was horrible. Video to follow.
Car Specs:
2006 Evo IX SSL
Custom Apex Muffler and Brake TBE
KUNiiiZZZEEE Dial-IN tune on 93 (inco9nito99)
Halman rx MBC
K&N Cone Filter
Exedy Twin Plate HD Clutch
Swift Sport Springs
Full Weight minus spare
All-season tires
Total of 5 runs. 13.2, 13.2, 13.0, 12.9, 12.9. Weather was 50.
Best run below. I launched at 4500 and was spinning.
60 ft.........2.1499
330ft........5.5749
1/8ET.......8.4260
1/8MPH....85.53
1000ET....10.8959
1/4ET.......12.9708
1/4MPH....109.71
Thoughts? Suggestions?
Old Nov 14, 2010 | 09:44 PM
blackgsx01's Avatar
raise your 2-step to 6000 and work on your 60ft. Those were pretty much the same mods I had exept for the twin disc and I hit a 12.3@110mph with a 1.7 60ft.
Old Nov 14, 2010 | 09:48 PM
dtrackstar's Avatar
i think my two step is at 6000. but when I slipped the clutch at 6000, I was spinning really bad
Old Nov 14, 2010 | 11:05 PM
sleeper04's Avatar
work on your launch for sure... once you get that 60' you are at a mid to low 12, practice practice. good luck
Old Nov 15, 2010 | 07:36 PM
dtrackstar's Avatar
Thank you! Any other suggestions?
Old Nov 15, 2010 | 07:47 PM
Spoolin4g63's Avatar
set 2step at 6k, lower tire psi to about 20 and that should help out your 60ft
Old Nov 15, 2010 | 07:50 PM
Force-Fed Performance's Avatar
Just takes seat time man. Dont worry stick with it and you will be fine.
best advice I ever got is dont go drag racing like you are scared of breaking your car. Pretend you are driving someone elses car and you dont care if it breaks lol.
Old Nov 15, 2010 | 09:16 PM
dtrackstar's Avatar
I drive it hard. No regrets haha. I slipped the clutch at 6000, and I spun for awhile
Old Nov 16, 2010 | 11:13 AM
Most-Wanted's Avatar
pm'd. Just saw your on all seasons. But regardless controll the wheel sping with clutch control. I would say 6K will work although I always use and recommend 6500 on a regular street tire. Good luck.
Old Nov 16, 2010 | 01:49 PM
dtrackstar's Avatar
pm'd back. Thank you. I need to lower the tire psi or get new tires especially since I don't drive it in the winter
Old Nov 16, 2010 | 02:00 PM
fqjdmct9a's Avatar
just some more practice, all you need is a better sixty.
Old Nov 16, 2010 | 05:40 PM
tlcoll1's Avatar
Your car is running very well. Keep practicing - you'll drop 1/2 second and pick up another MPH or so just with a 1.7 60' (definitely attainable w/a 6000 RPM good launch) and will be 12.2x's with some practice on your 1-2 shift.
Tom
Old Nov 20, 2010 | 04:44 PM
C130flyer's Avatar
I 100% agree with this statement. If you want to go as fast as your car is capable this is what MUST be done.
Old Nov 20, 2010 | 04:55 PM
Srt-4 Turbo 7's Avatar
MPH is there. Just seat time.
Old Nov 20, 2010 | 07:40 PM
dtrackstar's Avatar
I'm looking forward to next season. May be doing some upgrades . Going to be a good day once I get my 60 right. Thanks for all the advice!
