hks 7460r evo tuned by jms racing on e85
Old Feb 17, 2011 | 06:12 PM
fabcas311's Avatar
hks 7460r powered evo 8 tuned by jms racing on e85
here's the vdr dyno
vdr stats:
Weight: 3263 + 280 occupancy weight (I weight 240, rougly 40lbs of tools/parts in car)
Tire Diameter: 25.7 (Pirelli Rosso 245-40-18 on Rota P45 rims)
Gear: 3rd
Outside temp 50+ degrees
Graph shows the 3rd gear pull on E85 with a 29psi spike of boost holding 24psi to redline.
Dynojet 1.09 correction.
MODS:
Evo VIII GSR
HKS 7460R turbo
Shearer 02 Dump Housing
Kelford 272 Cams with springs/retainers
ETS Intercooler and piping
Forge BOV
megan ex mani
hks intake
megan dp/tp
agency power ti exhaust
Hallman Pro MBC
FIC 1050cc injectors/Walbro pump
ACT street strip clutch/HD PP
Tephra V7 Dual map/switch tuning for 93/E85
Stock porting/stock block
BEST RUN: street tires(18-20psi),1/4th tank of gas,gutted trunk
i only weigh 130lbs,Track Elevation: 96 feet
temp: 76 deg
i dunno but it doesnt have the 1/4th mph
my other best run was a 11.5 @123mph
r/t...........252
60'.....1.670
330.....4.705
1/8.....7.227
mph......97.58
1/4...11.248
mph......???????
thanks
fabiene
Old Feb 17, 2011 | 06:22 PM
06MREvo's Avatar
So you went to the track again tonight and ran an 11.2? Haha jesus man!
Old Feb 17, 2011 | 06:24 PM
fabcas311's Avatar
yes! i couldnt sleep last night thinking that i can do better!
Old Feb 18, 2011 | 07:02 AM
Nissan2Evo's Avatar
Great Job Fabiene! I knew once you got a little more seat time with the car low 11's were going to be right there. I'm impressed you knocked it out with that rim/tire combo!
Thanks again for bringing the car boss!
Old Feb 18, 2011 | 05:36 PM
KCtron's Avatar
very nice set up!
Old Feb 19, 2011 | 10:32 AM
Widoww's Avatar
nicely done, great looking car, slap some slicks on and hit 10's
Old Feb 20, 2011 | 02:22 PM
truplayboy's Avatar
great times on that setup
Old Feb 22, 2011 | 05:48 PM
MikeB@FFTEC's Avatar
Nice results.
Old Feb 22, 2011 | 10:41 PM
project_skyline's Avatar
Thats pretty dam good for the car weight and using those type of street tires!
Congrats man!
Old Feb 25, 2011 | 10:54 AM
fabcas311's Avatar
thanks guys!!!!...i will definitely go back to the track with lighter wheels and better tires!...........
Old May 12, 2011 | 12:18 PM
fugiwara's Avatar
I have the same turbo with the new cams step 2 cams.
you weigh 240lbs!! that's a lot of weight added to the car, I weigh 100lb less than you, 100lb will make a difference.
Old May 12, 2011 | 12:42 PM
fabcas311's Avatar
badass!.thats my tuner's weight.............i only weigh 130lbs
Old May 12, 2011 | 02:44 PM
Nissan2Evo's Avatar
I'm working on that weight reduction
Old May 13, 2011 | 10:29 AM
Black Momba's Avatar
thats some determination good work on getting that low 11 pass!!
Old May 14, 2011 | 09:11 AM
R/TErnie's Avatar
Nice work! Glad to see other people enjoying this little turbo!
