16" Rotas & QTP's with the stock brakes!
Old Dec 3, 2011, 02:49 PM
  #106
rodent's Avatar
Yes, higher offset, the farther they go in.
That sucks you can't find any and I'm sure you tried this place -
http://www.vexmotorsports.com/Rota-W...s-_p_6138.html
I was going to sell my white Slipstreams (mint condition) locally to someone but let me check with him and see if he still wants them. If not they will be up for sale. I was going to get a different color in the spring since I don't like the white on white as much as I thought I would.
Old Dec 3, 2011, 03:15 PM
  #107
mitsevo03's Avatar
Yea that's actually where I got my wheels from. Thanks for the info man I really appreciate it alot I'm just gonna go ahead and order some 27mm spacers so they will be here when the wheels are. I guess it doesn't really matter tho my car is in the shop and will prolly be there til a little after christmas I'm just trying to get ready for next racing season
Old Dec 3, 2011, 03:56 PM
  #108
mitsevo03's Avatar
Which spacers are better hub centric or lug centric?
Old Dec 3, 2011, 04:07 PM
  #109
rodent's Avatar
You need hub centric like these.
http://www.ebay.com/itm/27mm-Front-R...sories&vxp=mtr
The other thing I worry about +45 is if the rears will clear without spacers. I would consider getting just one wheel and do a test fit. It should be fine plus you could verify the exact thickness of spacer you really need. You may find the front needs less of spacer.
Old Dec 3, 2011, 05:40 PM
  #110
mitsevo03's Avatar
That's good help man thanks for the info. Yea I'll prolly put the 20mm spacers I got on the rear to kinda even it out some. I honestly didn't know it was gonna be this much trouble or I would have just went with a small brake kit and 15s lol
Old Dec 3, 2011, 05:49 PM
  #111
rodent's Avatar
If you already have the 20mm spacers, I'd try them first before you order the 27mm and see how much you really need. Yeah, these wheels can be a PITA but still cheaper than the small brake kit. I tried to find a light wheel that doesn't need spacers such as the RPF1 but it doesn't exist.
Old Dec 13, 2011, 12:11 PM
  #112
rodent's Avatar
Just sold my white Slipstreams and ordered a set in this finish:
Same 16x7 5x114 +40 size as my white wheels
Discount Tire said 6-8 weeks plus I got a $30 Visa gift card.
Old Dec 13, 2011, 01:08 PM
  #113
mitsevo03's Avatar
Ah man I wish I woulda known discount tire could get them I still ain't had a chance to fit mine yet. They look good man
Old Dec 20, 2011, 05:24 PM
  #114
TurboTravis's Avatar
Questions..
To do 15x7's all the way around, what offsets and spacers are required so the car does not look like a reverse trike?
Old Dec 20, 2011, 10:09 PM
  #115
caLi4G63's Avatar
Originally Posted by TurboTravis
Questions..
+35 works but it may differ depending on the wheel design. I imagine you have a small brake kit in the front?
Old Dec 20, 2011, 10:35 PM
  #116
Yes I have small brakes.
Old Dec 25, 2011, 11:06 AM
  #117
Drill_Sergeant's Avatar
for anyone using the grids, the spacers have to be the pass through design with extended lugs, 22mm spacer.
someone correct me if im wrong, but the v2 spacers (ichiba) the OEM lugs/studs stick out past the spacer itself and the grids don't have the proper pattern on the inside of the rim to clear the OEM studs.
Old Mar 9, 2012, 11:10 AM
  #118
rodent's Avatar
Just an update on this. I never got these wheels.
Rota basically told Discount to pound sand and said they don't make that wheel in a 5x114 BP in that finish. Rota then told the Discount Mgr. that he never asked for that finish when he ordered them even though I was standing right there when he did order on the phone. I could only get white or black. After 11 weeks of waiting and now being told they will never make that wheel in my BP with that finish, I canceled the order. I wasn't too happy.
So today I ordered a set of these:
http://classic.wheelpros.com/images/...ing/MR2388.jpg
16x7 Motegi Traklite +42
Around 12 lbs each
Not a huge fan of black wheels but I'm curious how they will fit over the factory brakes.
Also- I still have my white slipstreams for sale. I bought them back from Tobz but then decided to try this wheel for grins.
Old Mar 10, 2012, 11:13 AM
  #119
rong.'s Avatar
where did you order them from?
Old Mar 10, 2012, 03:38 PM
  #120
rodent's Avatar
Ebay for $677
Quick Reply: 16" Rotas & QTP's with the stock brakes!
