i had 9s and then it was taken away.
here is some stuff that i gathered.
ABS unit. 5lbs
ABS lines 1lb
ABS master 1.9lbs.
ABS delete kit is 3lbs. so basically all you save if 5 lbs. but you gain a hole lot of room.
stock engine harness. i weighed it in at 11lbs. but i did disassemble a lot of it. but i put everything on the scale. so 11lbs it is.
the bracket that holds 3 sensors next to the abs unit was 1.8lbs. yes its deleted now.
so far i dropped 6.8lbs and cleaned up the bay a hell of a lot.
the engine harness i hope to see 5lbs off that. i ordered a chasebay's engine harness. but there going to custom make it to my liking. meaning. i do not use the rear o2 sensor, there deleting ABS out of it, and i do not use 3 other sensors that where hooked up to emissions and such. soooooooo why have them at all? there being removed from the hole harness. if i do not need it then it must go. i will have a complete review and thread coming soon once i get the harness in.
so. in the end i am hoping for 11.8lbs+
ABS unit. 5lbs
ABS lines 1lb
ABS master 1.9lbs.
while i am waiting for my engine harness i am cleaning up the fire wall some. basically just getting the dirt and grim off it. and then i saw a opportunity for carbon fiber.
well here it is. once the car is all back together you wont be able to see this but i will know it is there. haha. instead of buying the ugly paper cover used for the A/C delete i decided to make mine out of carbon fiber.
I can't believe I've missed this thread this long.
Glad you made it out to the shootout again. You were so close to your 9 second pass! You will get there!
The autocross is addictive! I want to do one every week! I hope to have my car set up better than it is for next years events. Don't forget Dan, we run one in the spring too!
thanks man. i still have a little bit of time before the season is over to get that 9 second pass.
the AutoX stuff is kick ***. i already know i am doing it again next year. i also am thinking of buying a good tire for it as well. i didnt know you held a spring event. i will see what i can do about trying to make it. that would be a cool trip to kick off the season. is there a thread on it? or what is the event called i can go find it.
Good to hear your girlfriend enjoyed herself. The event isn't like most others, there is SO much going on, so many people with a common interest that it's more of a social gathering than you get at nearly any other race.
Here's a link to our spring race:
http://highboostforum.com/forum/show...d-and-3rd-2012
That carbon fiber block off plate is a good idea. I like the CF. Hope you get your 9 second pass this season Dan. Im trying to get out there as well this weekend. I havent been back since the Shootout. Hopefull we will have the time slips we want by the end of the season!
little update. i plan 1 last trip to the track before the end of the year. i have 100% given up on 100oct fuel for a few reasons. 1. cost. 8.58 a gallon here. i spent way more then i wanted on fuel this year. the car made great power on it but for some reason still does not run 9s. 2. my local sunoco does not supply it anymore. i do not know why and i am not traveling 1.5 hours then carting 100oct fuel back home.
so i decided to go to E85 fuel. i will have to cart it 45 minutes to get it to my home but its also 3.50 a gallon or something. so its much more worth it. i really am disappointed for a few reasons. the car ran 10.3 on pump ''93'' at 137. i added 100hp to the car and it runs consistent 10.4s at 141. i do not understand it. its disappointing to say the least. anyways when i do the E85 tune i do not plan to run the car with the added HP. i will be running the car with the same HP as i have now until i see some sort of improvement. then i will up the boost and add the extra power and see where that ends up.
i do not know when ill get the E85 tune. i have to much going on in my life right now to even worry about it and i am also short on funds. so i might not even make it out this year. who knows. but this is my plan. lets see how well it stays on track.
i just set a tune date for oct29th for E85. which means nothing as i am not running full bore until i feel and see some sort of change. then ill raise the boost for the added HP. i guess we can plan for that sunday?????
Nice! Either that Sunday or the Sunday after should work for me...Looks like I need to order my stuff asap!
