Top 20 Fastest/Quickest Stock Appearing Turbos for 2012
Screen Name - Date - Shop Affiliation - Evo Generation - Engine/Turbo Setup - ET/MPH
vmrevo9 - Feb 12 2012- n/a - Evo 9 RS- stock block/head, GSC s2 cams, 1000cc inj, Ported BBK Full, 3" TBE, perrin intake w/amsoil filter, 25psi tapered to 22, Spoolinup COP 1 step colder plugs. street tires at 25psi - 11.789 @ 118.06
engine bay shot
when turbo was installed
weight reduction was spare tire/jack removal and 1/4 tank of gas.
engine bay shot
^^Nice job man! List updated! Definitely more left in that BBK Full, crank the boost up some more! Your riding 4th gear out through the traps & not shifting to 5th, correct?
definitely not shifting to 5th
im crossing the line at the top of 4th (~7k). i have my rev limiter set to ~8200rpm
i plan on retuning the car and setting the boost to 28 but i think i have to upgrade the intercooler before hand.
28 psi will be funnnn with the BBK Full. Get ready for that tq man! As long as you can knock off a 1.6X 60 ft again @ 28 psi I see you running 11.5Xs or faster at 120mph+!
Englishtown opens up Sunday and I am going to try my best to get there, Im having a weird wastegate flapper issue, Im getting exhaust out my dump tube at idle recently. I definitely want to get there this weekend
check your tension on the wastegate arm and tighten it! i had the same issue for a while and couldnt figure it out for the life of me
I spoke to Bob on the phone today about some stuff, he said to check that there is no burrs on the casting that might prevent the flapper from shutting. I dont think its that since it was fine just a few days ago.
This happened just after I tried brake boosting for the first time ever on the highway. Im expecting the worst...either the flapper is no longer seating right for some odd reason or somehow the flapper warped.
