Top 20 Fastest/Quickest Stock Appearing Turbos for 2012
List is open to FP White, FP Green, FP Red, FP BLACK, BBK Series, HKS 7460R, ATP turbos, MAP EF Series, ATP Turbos (Australia) Powered Cars ONLY!!
Time slip or at least break down of the time slip is required!!!
All passes must be to the 100th in both MPH and ET (ex 10.03 ET or 123.55 MPH) but to the thousandth would be ideal.
Here is the lists format again...
Screen Name - Date - Shop Affiliation - Evo Generation - Engine/Turbo Setup - ET/MPH
List 1 (Evo VIII & IX) - Best E.T. in the 1/4 mile - Updated 12/10/12
NAME / Date / Main Sponsor / Evo Type / Setup / ET
1. Emery at STM / 7/11/12 / Evo 8 / FP RED, Stock Block, weight reduction / 9.436ET
2. Flyin_banana / 12/8/12 / ATP Turbo / Evo 8 / ATP GTX3582R, Built 2.0L, E98, QTPs, Sheptrans 4.11 FD, 39 PSI / 9.742ET
3. pls1968 / 2/26/12 / Evo 9 / FP BLACK, Built 2.0, Hoosier DR's, E85, Full Interior, AC, 40psi / 10.029ET
4. Mikey@Spec-Ops / 3/25/12 / Spec-Ops Motor. / Evo 9 / FP BLACK, LR 2.4, E85, M&H Slicks, Sheptrans 4.11 FD, ER SD Program. Tuned by Freddie, 29psi / 10.117ET
5. JunkboxEvo / 8/5/12 / CLM Motorsports / Evo 9 / FP RED, stock block, unported head, m&h dot tires, pump e85 / 10.371ET
6. AreSTG / 8/25/12 / Spec-Ops Motorsports / Evo 8 / FP BLACK, Spec-Ops 2.4LR, Race gas / 10.399ET
7. 1RedEvo / 5/9/12 / ATP Turbo / Evo 8 / ATP GTX3576R , Wiesco pistons, Eagle rods, GSC S3s, E85, Hoosier DRs, 36 PSI / 10.423ET
8. tscompusa (Tom) / 9/8/12 / TSCOMPTUNED / Evo 8 / FP BLACK, E85, BR 2.3, SD, 35psi, 3200lb & Hoosier qtp / 10.839ET
9. TheKidd113 / 9/14/12 / Spec-Ops Motorsports / Evo 8 / FP BLACK, 2.3L, SD tuned by Matt, c16, Hoosier DR's / 10.90ET
10. sc00by / 7/20/12 / Jacks Trans & Servion Tuning / Evo 8 / FP RED, built 2.0, 3250lbs w/ driver, Motorcycle slicks / 10.92ET
11. DSM6382 / 6/6/12 / ATP Turbo / Evo 8 / ATP GT3076R, stock 2.0L motor, E85, slip street tires, full interior, stock maf, 30psi / 10.933ET
12. 5LEEPERISAH23I / 12/2/12 / TSCOMPTUNED / Evo 9 / FP BLACK, E85, TSCOMPTUNED 2.4L, V7 SD, 3366lb, Junk tires, shifted into 5th / 11.016ET
13. Wizzo 8 / 10/21/12 / Evo 8 / FP BLACK, SM built Block, street tires / 11.093ET
14. Dan08 / 9/21/2012 / Evo 8 / FP BLACK, 2.3 stroker, E85, Wingzperformance tune, street tires @ 35psi / 11.175ET
15. Macaroni / 12/9/12 / Self tune / Evo 8 / FP RED, built 2.0L, Maximal 116, 31 psi, 225 primewell's / 11.178ET
16. 420a-t / 10/7/12 / Evo 8 / FP BLACK, stock block, ecmlink, qtp's, self tuned, e85 / 11.183ET
17. 4g63girl / 8/18/12 / STM / EVO 8 / MAP EF3, Buschur 2.0LR, E85, 2815lbs / 11.187ET
18. Turbofig / 8/17/12 / Evo 9 / FP White, E85, Stock block, M2 cams, stock 235/45/17 tires / 11.325ET
19. PrimerSdime / 5/18/12 / Evo 8 / FP BLACK, stock block, stock cams, bolt ons, snow tires, e85, self tuned, 27 psi / 11.419ET
20. Ronnie Size / 8/19/12 / VRSF / Evo 9 / FP RED, built 2.0, pump gas, street tires, GSC S2 / 11.420ET
List 2 (Evo VIII & IX) - Fastest MPH in the 1/4 - Updated 12/10/12
NAME / Date / Main Sponsor / Evo Type / Setup / MPH
1. Flyin_banana / 12/8/12 / ATP Turbo / Evo 8 / ATP GTX3582R, Built 2.0L, E98, QTPs, Sheptrans 4.11 FD, 39 PSI / 147.964MPH
2. Emery at STM / 7/11/12 / Evo 8 / FP RED, Stock Block, weight reduction / 147.01MPH
3. 1RedEvo / 5/9/12 / ATP Turbo / Evo 8 / ATP GTX3576R , Wiesco pistons, Eagle rods, GSC S3s, E85, Hoosier DRs, 36 PSI / 139.88MPH
4. pls1968 / 2/26/12 / Evo 9 / FP BLACK, Built 2.0, Hoosier DR's, E85, Full Interior, AC, 40psi / 139.72MPH
5. AreSTG / 8/25/12 / Spec-Ops Motorsports / Evo 8 / FP BLACK, Spec-Ops 2.4LR, Race gas / 135.91MPH
6. 5LEEPERISAH23I / 12/2/12 / TSCOMPTUNED / Evo 9 / FP BLACK, E85, TSCOMPTUNED 2.4L, V7 SD, 3366lb, Junk tires, shifted into 5th / 133.68MPH
7. tscompusa (Tom) / 9/8/12 / TSCOMPTUNED / Evo 8 / FP BLACK, E85, BR 2.3, SD, 35psi, 3200lb & Hoosier qtp / 133.16MPH
8. Mikey@Spec-Ops / 3/25/12 / Spec-Ops Motor. / Evo 9 / FP BLACK, LR 2.4, E85, M&H Slicks, Sheptrans 4.11 FD, ER SD Program. Tuned by Freddie, 29psi / 133.02MPH
9. TheKidd113 / 9/14/12 / Spec-Ops Motorsports / Evo 8 / FP BLACK, 2.3L, SD tuned by Matt, c16, Hoosier DR's / 131.81MPH
10. Wizzo 8 / 6/30/12 / Evo 8 / FP BLACK, SM built Block, street tires / 131.44MPH
11. 4g63girl / 8/24/12 / STM / EVO 8 / MAP EF3, Buschur 2.0LR, E85, 2815lbs / 131.00MPH
12. DSM6382 / 6/6/12 / ATP Turbo / Evo 8 / ATP GT3076R, stock 2.0L motor, E85, slip street tires, full interior, stock maf, 30psi / 130.47MPH
13. 420a-t / 10/7/12 / Evo 8 / FP BLACK, stock block, ecmlink, qtp's, self tuned, e85 / 130.43MPH
14. sc00by / 7/20/12 / Jacks Trans & Servion Tuning / Evo 8 / FP RED, built 2.0, 3250lbs w/ driver, Motorcycle slicks / 129.39MPH
15. JunkboxEvo / 8/5/12 / CLM Motorsports / Evo 9 / FP RED, stock block, unported head, m&h dot tires, pump e85 / 128.48MPH
16. PrimerSdime / 5/18/12 / Evo 8 / FP BLACK, stock block, stock cams, bolt ons, snow tires, e85, self tuned, 27 psi / 126.18MPH
17. jwdp54 / 10/20/12 / Wingz Performance / FP GREEN, 2.3L, GSC S2, 1450's, double pumper, speed density, e85 @ 30psi / 123.46MPH
18. Dan08 / 9/21/2012 / Evo 8 / FP BLACK, 2.3 stroker, E85, Wingzperformance tune, street tires @ 35psi / 122.60MPH
19. gcube99 / 4/22/12 / Springy Performance / Evo 8 / ATP GOLD, E85, stock motor, 3" zorst, 1600cc Injectors, Deatchwerks dw301, Tuned by Danny, 26psi / 122.22MPH
20. xRoguex / 8/19/12 / TSCOMPTUNED / Evo 8 / FP BLACK, 93oct, BR 2.4L, V7 SD, Full Weight + Sound system / 120.69MPH
List 3 (Evo X) - Best E.T. in the 1/4 mile - Updated 6/1/12
1. BlueX / 4/15/12 / ATP Turbo / Evo X / ATP GTX3576R, pistons, rods, cams, E85, Hoosier DRs, 32 PSI / 10.51 ET
2.
3.
4.
5.
List 4 (Evo X) - Best MPH in the 1/4 mile - Updated 6/1/12
1. BlueX / 4/15/12 / ATP Turbo / Evo X / ATP GTX3576R, pistons, rods, cams, E85, Hoosier DRs, 32 PSI / 135.61MPH
2.
3.
4.
5.
List 5 (Ralliart) - Best E.T. in the 1/4 mile - Updated 9/6/12
NAME / Date / Main Sponsor / Setup / ET
1. Ralliart26 / 8/31/2012 / Ralliart / BBX-Full, 93oct, Stock block, GSC cams, 235/45/17 tires / 11.71ET
2. Glenn1234 / 8/12/12 / Beeble Tune / Ralliart / MAP EF2, stock block, e70/85, 26psi / 11.977ET
3. AWDralliart09 / 4/8/12 / ER tune / Ralliart / MAP EF2, stock block, wheels, interior, 92 oct, 25psi / 12.24ET
4.
5.
List 6 (Ralliart) - Best MPH in the 1/4 mile - Updated 9/6/12
NAME / Date / Main Sponsor / Setup / MPH
1. Glenn1234 / 8/12/12 / Beeble Tune / Ralliart / MAP EF2, stock block, e70/85, 26psi / 115.35MPH
2. Ralliart26 / 8/31/2012 / Ralliart / BBX-Full, 93oct, Stock block, GSC cams, 235/45/17 tires / 115.31MPH
3. AWDralliart09 / 4/8/12 / ER tune / Ralliart / MAP EF2, stock block, wheels, interior, 92 oct, 25psi / 110.21MPH
3.
4.
5.
2.
3.
4.
5.
2.
3.
4.
5.
4.
5.
3.
4.
5.
Well I didnt even make it to the track last year due to an extended build time and weather. Also being busy almost every weekend with weddings and stuff. I promise you this year I will get on the list and it will stick
. No messing around this year.
Flyin_banana / 1/15/12 / ATP Turbo / Evo 8 / ATP GTX3582R, Built 2.0L, E85, QTPs, Sheptrans 4.11 FD, 39 PSI / 9.93 ET Best MPH 144.969
Made the 10.2 run with 35 psi. The track hooked good on that run, 1.52 60ft
Haha, So you picking up an ATP turbo now?
