need drag help!
Old Sep 21, 2012 | 06:22 PM
spadednick88's Avatar
need drag help!
Whats up guys. I only have 1 more track day till the season is up and i really wanna hit a low 11 or even high ten. I cant seem to break 12's and i know my car has 10's power in it im just a ****ty driver and could use aome drag/launch advice. My 60' is a 2.0 flat (****TY I KNOW LOL) any decent draggers i need help
Old Sep 21, 2012 | 06:25 PM
sho669's Avatar
Breakdown of full slip?
BTW my 7700# F250 diesel 4x4 60's 1.90 all day!
Old Sep 21, 2012 | 06:30 PM
Dam you! Lol in hitting low 12's at 120 mph. My car has was tuned and dynoed at 600+ on a dynapack. And i just feel so slow!! I checked boost leaks before race and none! What am i doing wrong!!! Btw im in utah at 4200 ft. Pushing 32 psi
Old Sep 21, 2012 | 06:48 PM
sho669's Avatar
600+ and 120mph don't add up.
I ran 11.7's@116 running 350/350 on a Mustang dyno and my car is an SSL.
The air density isn't helping you I'd imagine but I wouldn't think it would cause that much of a drop.
Whats the rundown partswise that are on the car?
Old Sep 21, 2012 | 06:53 PM
I know right?? I have stock turbo guys beating me but my mod list in a jar
Built 2.4
Bc272s
Dw300 w/ boost a pump
Fic 1650's
40r with custom quick spool valve
Speed density
Tial wg and bov
All bolt ons stock intake manny
Old Sep 21, 2012 | 08:58 PM
Ev0ikon's Avatar
What PSI you see when you leave the line?
Old Sep 21, 2012 | 09:32 PM
My 2 step hits 10
Old Sep 22, 2012 | 03:58 AM
vaflyboi757's Avatar
Hows the boost recovery between shifts? Have you tried NLTS?
Old Sep 22, 2012 | 04:58 AM
AngryEvo8's Avatar
Is your 2.0 sixty from spinning or bogging? If its spinning you should try to lower your tire pressure accordingly or get a set of sticky tires. If its bogging raising the 2step to see if that helps. The 60ft and the 1-2 shift are key in making a solid pass.
Old Sep 22, 2012 | 09:58 AM
silverofs's Avatar
Keeping your car in power is your biggest problem. You need to nlts if you don't your turbo takes to long to spool between shifts. What clutch do you have ??
Old Sep 22, 2012 | 11:32 AM
I have sprung 6 puck. Ya i was thinking i need to setup my nlts. My big *** turbo is a pain i was thinking of dropping down to a 6262. And also i dont spin i slip the cluth and kinda bogs. But honestly ive only dragged 5 or 6 times in my life so the whole clutch slipping needa practice lol
Old Sep 22, 2012 | 02:46 PM
silverofs's Avatar
600+ hp should be good for traps in the 130's. Do you fall out of boost when you shift??
Old Sep 22, 2012 | 03:15 PM
Yes
TxFAkuma
Sep 15, 2014 04:52 PM
TarikH
Mar 23, 2014 09:05 AM
freethriftyz
Apr 20, 2013 06:16 PM
spadednick88
Oct 1, 2012 04:27 PM
