Need some tips, chasing 9's
Old Aug 4, 2014 | 08:38 PM
b16a95eg's Avatar
I've been chasing 9's for 2 years now, I missed most all of last year, so I finally got back in the seat and have made it to a couple track days. I CANNOT launch this car for the life of me. Here's a video, feel free to through any tips my way.
Set up:
Buschur 2.3rpm
AMS Turbo Kit-6466 Turbo
e85,
boost at 36psi
M&H Radials-22 psi in the vid
2 step at 6100
Shep Trans, Stock open diff T-Case
This wasnt my best pass, but its the only one that turned out decent on the gopro. Here's the slip:
Any tips would be appreciated, I know my launches need a LOT of work, but I'm having a hell of a time dialing those in.
Old Aug 4, 2014 | 09:46 PM
Evosick2332's Avatar
I would bump up the 2-step a little more. For your setup on a 6466, I think the 2 step should be higher. It's kind of hard to hear on the computer, but it seems like the car is falling on its face a little bit after launching. I would raise the 2 step a little bit. Maybe start at 6500-6600rpm and go from there and don't slip the clutch as much. Just my 02 man, but I think that will help out a lot.
Old Aug 4, 2014 | 11:32 PM
b16a95eg's Avatar
Thanks Joey, I'll bump it up a little bit. I had it higher before but it would just light up the tires. They actually prepped the track good this day haha
Old Aug 5, 2014 | 12:15 AM
lvtubasor's Avatar
Your 2step needs to be higher, im running same turbo, 7000rpm 2step, consistent 1.4xx 60ft, i slip the clutch a little then just letit go! Seems like youre shifting allright, But whatsup with that mph thou? should be at over 140mph if you want 9s! whats the power on the car what dyno?
Old Aug 5, 2014 | 09:17 AM
b16a95eg's Avatar
I have no idea why the car is trapping so low. First time out this year it did a 10.6@144, changed the trans from a stock one and it hasn't hit 140 since, I'm actually bringing it down to the shop I get my tuning done at today to see if it's down on power or what. The car weighs 3210 with me in it and made 706 on a mustang dyno back in may.
Old Aug 5, 2014 | 11:02 AM
lvtubasor's Avatar
With that power and weight with a good 60ft mid 9s, i ran 9.6@146 same weight, 650hp MD with a garret GT37r, 6 month ago, first pass at the track, you have an outside video of it running 10s for any chance?
Old Aug 5, 2014 | 11:18 AM
b16a95eg's Avatar
Well on the dyno today first pull was only 604 same dyno, so now to find why the power is so far down
**update** Hydraulic tensioner for the timing belt started going bad, causing timing to jump a tooth. Got it all put back together and she rips again. Now I can't wait to head back to the track
Old Aug 6, 2014 | 04:17 PM
lvtubasor's Avatar
Ha there you go, i knew there was something wrong, with over 700hp easy 150mph=9s with the way i see you drive!
Old Aug 6, 2014 | 06:10 PM
mitsubeastlee's Avatar
glad you found the fix.
Old Aug 6, 2014 | 08:09 PM
b16a95eg's Avatar
Thanks guys, I can't wait to head back to the track.
Old Aug 8, 2014 | 07:15 AM
itsmrrizz2you's Avatar
Yea I would bump up 2 step 6500 rpm and maybe a little less tire pressure. I'd start 18 in front 20 in rear has worked good for me. Also maybe let the 2 step build for another sec or 2. Should get you ripping out the hole.
Old Aug 8, 2014 | 04:14 PM
b16a95eg's Avatar
Thanks for the input, i'm going to work on trying everyone's tips the next time at the track and see if I can get something to work!
Old Aug 26, 2014 | 03:57 AM
TheKidd113's Avatar
Any updates on this. I'm curious because I am also chasing 9s. I make 584 on a mustang, car weighs 2950 without me in it (full interior street car) and ran a 10.00 on an FP Black.
Old Aug 28, 2014 | 10:38 PM
b16a95eg's Avatar
I'll be going back to the track next weekend for the MAP Proving Grounds, we'll see how it goes!
Old Sep 7, 2014 | 06:46 PM
b16a95eg's Avatar
UPDATE: So so sooo close. Best pass of the weekend was 10.02 @141. I should have kept in it in 1st gear rather than pedal it to try and stop the spinning.
Here's a vid, You can hear the little pause that cost me my 9 haha
Here's from the other side. Sorry for the quality. But you get the idea
