Porshce tt 911 vs My Dynoflashed EVO !!
Old May 28, 2004 | 09:15 AM
matt55's Avatar
2001 tt 911 = 12.5x @110 vs My buscher stage 1 + Dynoflashed EVO =12.28@113 I have STOCK cams , IC , turbo , race fuel mid 80 temps VERY humid . That is the fastes/quickest ive hear about with these mods ( some cat said he run 12.20 with full stand alone) 911 did pull sum 12.4x's but that was his best I saw
Old May 28, 2004 | 09:17 AM
HoLeeRay's Avatar
that's hot. wish you had a video of it, haha.
Old May 28, 2004 | 09:18 AM
WheresMyEvoRS's Avatar
He probably couldn't drive. A properly driven stock 6-speed 996 Turbo will run 11.9 to 12.1 under the right conditions with the right driver.
evo542's Avatar
congrats on beating him with just some boltons
Old May 28, 2004 | 09:20 AM
matt55's Avatar
All nite the 911 was cuttin .5-.6 lights ? ! Looked like he was drivin his *** off
Old May 28, 2004 | 09:29 AM
RENN-ART's Avatar
the reaction time doesnt mean much at all for ET.. it's the 60 ft that tells how he launches
Old May 28, 2004 | 10:43 AM
matt55's Avatar
Piont I was tryin to make was that the guy could drive , 1.84 60' s for the 911 and I got 1.81 60's
Old May 28, 2004 | 10:52 AM
naucrx's Avatar
Did you get a custom Dynoflash or the mail-in flash? That is a nice time.
Old May 28, 2004 | 10:57 AM
matt55's Avatar
Mail-in flash
Old May 28, 2004 | 11:00 AM
naucrx's Avatar
Buschur Stage 1 includes a SAFCII. You aren't using that are u, just the Dynoflash, right?
Old May 28, 2004 | 11:04 AM
matt55's Avatar
Both , s-afc is so i can pull a little fuel out when i use 100 + octane , that time i was spinning kinda bad but when it did hook up i never felt my car pull that hard with just the s-afc . The dynoflash gave me a lot more TQ down low !!
Old May 28, 2004 | 11:15 AM
naucrx's Avatar
Ahh, I see. I might do the same thing. One of my friends is nagging me to get a SAFC and try some 100 octane or Toluene. I need a few fail safes in place first though, such as EGT gauge.
I have the mail-in Dynoflash also.
Old May 28, 2004 | 11:25 AM
TURBODAWG's Avatar
Hey Matt,
Nice job Matt. The track that Matt is going to is slightly uphill, especially in the last 1/8 of a mile. That could explain the lower than ideal times for the 911 turbo. It was also very hot and humid. A guy who couldn't drive in the 911 turbo would probably be in the 13's, not mid 12's.
The dynoflash does add alot of torque down low and seems to pull alot smoother up top. With a mail in tune you cant get the fuel tuned down perfect. He asked to add a little safety margin for car to car variances and fuel quality in the areas. I do the same thing when I go to the track and run higher octane fuel. The AFC can lean the fuel out slightly and the higher octane helps keep the timing in check. Nobody runs low 12's with a mail in ECU flash without leaning it out a little bit with an AFC or some fuel tuner. Custom tunes can be tuned to that degree but not mail in flashes.
Matt, did you get your new clutch installed?
Brian
Old May 28, 2004 | 11:34 AM
matt55's Avatar
Brian
Nope still on stock , you ready to put the new one in for me
Old May 28, 2004 | 11:44 AM
EVOMIZ's Avatar
hi i am that cat
nice times with the flash i had the mail in flash at one time but i got fired and now i have the aem .
congrad o n the nice times
i am about to install some cams so i can hit 11's
( some cat said he run 12.20 with full stand alone) 911 did pull sum 12.4x's but that was his best I saw [/QUOTE]
