post yor 1/8th mile times
Old Apr 16, 2005 | 09:50 AM
  #31
ldstang50's Avatar
Originally Posted by feautoevo
HaHa, spin tires, save clutch, =blow transfercase, I'd much rather use the clutch what it was designed for I pulled a 1.86 60ft time on the stock clutch and bone stock car with 1k miles on the car 8.62 1/8th mi 13.587 @99.59mi there is no compromise for learning how to properly drive your car, you cannot just rev to 7k and dump your clutch, you can snap half shafts or destroy your transfer case... anyhow just my .2
33k later, and 100 drag strip launches, daily driver and my xcase is still good. its all how you do. I don't side step, i just come up hard on it
Old Apr 16, 2005 | 11:56 AM
  #32
Corey's Avatar
Originally Posted by ldstang50
did you let off or something? that mph is really low for that time and 60'
I ran 7.9@ 85mph on a 1.6 60'
nice job though
some asked above if the high 7 guys are on pump or race. i was on pump
Yeah....I was pulling 1.8's and running 82mph and only running 8.5's. I was still on the stock clutch at the time. Seems you should be trapping a little faster than that.
I was the one that asked about 7's with pump gas. I'm a pump gas kind of guy and that is all I run. What do you have done to run in the 7's if you don't mind me asking?
Old Apr 16, 2005 | 12:00 PM
  #33
ldstang50's Avatar
At the time I had AEM intake, cat back, fuel pump, boost controller and dynoflash.
Old Apr 16, 2005 | 02:20 PM
  #34
Corey's Avatar
Damn...I have HKS dp, HKS cat back, test pipe, walbro, ebc, 264's, and a custom DynoFLash. That makes me wonder what my car is really capable of now. I also have a Exedy twin disk now. I the stocker last time I was at the track.
Old Apr 16, 2005 | 02:38 PM
  #35
SterlingEvo's Avatar
8.1 @ 85 with BR Stage 1 (TBE/Int/Flash/20psi/93oct). Now going to stage 4 and hoping for a little better time
Old Apr 16, 2005 | 03:01 PM
  #36
ldstang50's Avatar
Nice sterling. work on your 60' and you have a 7sec car
Old Apr 17, 2005 | 07:10 AM
  #37
Thanks, man. Actually I've been working on more than my 60' this winter... should be solidly into the 7s
Old Apr 17, 2005 | 09:59 AM
  #38
Warrtalon's Avatar
Originally Posted by specialk22oz
i was wanting to see everyones 1/8th mile times and what mods were done
my times are a 11.86 in stock 4cyl automatic lancer oz
Stock MR - 8.4@80mph 1.92 60'
Old Apr 18, 2005 | 03:40 PM
  #39
CBRE's Avatar
7.00@101.84 stock turbo. Turn up the boost!
Old Apr 21, 2005 | 02:02 PM
  #40
InsaneEVO's Avatar
I was very happy to run an 8.01 @ 88.61 in temps that reached 85 degrees. This was on race gas. 8.04 @ 87.6, 8.06 @ 87.1 and 8.08 @ 87.6... I really wanted a 7s pass!
Old Apr 21, 2005 | 02:12 PM
  #41
Man... so damn close Isn't that frustrating, when you're 1/100th of a second off??? Like one microscopic slip of the clutch or shift and you're there
Old Apr 21, 2005 | 06:06 PM
  #42
Corey's Avatar
What kind of power you think your car is making on race gas? Seems like my car is very close to 7's since I have cams and a clutch. Wonder if this is possible on good ol' 93?
Old Apr 21, 2005 | 06:33 PM
  #43
InsaneEVO's Avatar
Actually, 2/100ths off But yeah, frustrating! I was more than happy though, this track always netted me 2-3 1/10ths slower in my 3000gt and the best the EVO had done (on a 50 degree day, but minus catback and injectors) was 8.11 @ 83.14 en route to a 12.70 @ 106.82. When I pulled the first 8.04 @ 87.6 I almost crapped my pants and knew that I'd hit a 7 that day, but oh well...
Btw - I also prefer to turn the tires over rather than slip the clutch. The catch is that you have to ENSURE that you turn the tires over. Best 60' in my 3000 was a hard enough launch that the ***-end stepped out. 122k miles and never had a transfer case problem even with 275s. I've got handfulls of 1.7s in the EVO including a 1.74 spinning every time.
I've seen a signature stating 298 at the wheels and a 107mph 1/4 mile pass so I'd say I'm close to that number having run 107.12. At 88.6 through the 1/8th and gaining the same in the 2nd half I'd be at 111.7.
Old Apr 21, 2005 | 07:51 PM
  #44
plokivos's Avatar
8.321 @84.94 mph.
ran faster when I was spiking to 24psi and tapering to 20 psi before, just for the 1/8 mile, then i would slow down dramatically on the 3rd and 4th gear getting slower 1/4 time for some odd reason.
I think I ran like 7.9, at 88mph before I got my mbc and the clutch.
I got better 1/4 after the act clutch and mbc though... which makes me think just now, maybe it'll be better for me to take the mbc out...
maybe it's the clutch that's helping with the 1/4 mile time, not mbc...
Old Apr 22, 2005 | 05:28 AM
  #45
ldstang50's Avatar
man your so close. Your traps indicate you should be high 7s. I would have to say its in your launch. 1.74 isn't bad. But when you pull a 1.66 or better you know you got it. That will be a 7 sec run right there. You are killing me in traps by almost 3mph, but i have .0855 on you in the 60'. what clutch are you running, stock? If so, those are really good 60s for a stocker.
