Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
What RPM do u shift?
Old Jan 16, 2007 | 10:47 PM
  #61
sean2sean's Avatar
1, 2, 3, about 3500.... rest of the gears... less...
Old Jan 16, 2007 | 11:19 PM
  #62
evo637's Avatar
DD: 3500-4000
Trackday: 1--2 5000 2-3 redline 3-4 redline never had a chance to use 5th at open track
Old Jan 17, 2007 | 01:54 PM
  #63
TurboKaren512's Avatar
I shift right around 3,000 each time.
Old Jan 17, 2007 | 02:03 PM
  #64
4Gsixty3's Avatar
used to shift around 3K with the stock turbo, now shift around at 4K with the 50trim.
Old Jan 18, 2007 | 01:01 PM
  #65
Zoom's Avatar
depending on gas prices...... about 3000 rpms. Highest while just dinkin around town would be 4000. Track nights...we won't go there. I don't want to be shot.
Old Feb 6, 2007 | 01:35 PM
  #66
Blitz's Avatar
I've had the car for less than a month, so I'm hardly an expert on how best to drive it. I usually shift at 2,500 from 1-2 and between 2,000-2,500 for all the rest. I thought this would save gas as MIVEC kicks in at 3,000. Should I be shifting higher? It seems like a lot of people do.
Old Feb 7, 2007 | 12:50 PM
  #67
EVOB23's Avatar
Okay I shift over 3000 normally around 3500 the tilton doesn't like it. It makes the ride smother I think. Hard driving on pump with the 280 around 7300 race gas and high boost around 7700.
Old Feb 10, 2007 | 06:40 PM
  #68
cangriracing's Avatar
7,200 k to much for a stock mr?
Old Feb 11, 2007 | 03:35 PM
  #69
04evors's Avatar
I set my rev limiter at 8200, I no-lift to shift at 8k.
Old Feb 27, 2007 | 09:06 AM
  #70
evoIX15's Avatar
right when i hear the turbo spool up for daily driving, so ab 3k, but when racing...i redline that ho
Old Mar 3, 2007 | 09:21 PM
  #71
Jon54956's Avatar
I usually shift between 2500-3000. If the car is still warming up in these wretched Wisconsin winters, I make it a point to shift at around 2300... the car is pretty boggy if you do that, but I'd rather be far away from peak torque and HP than have the turbo spooling when my car is ice cold in -30*F temperatures.
Old Mar 3, 2007 | 09:27 PM
  #72
Jon54956's Avatar
You can most definitely hear the turbo spooling at 3000, but if you listen really carefully (at least with my car) you can hear the turbo at around 2500 rpm already.
It sure is fun taking the car to 3,500 and hearing the turbo a lot, though!
Old Mar 5, 2007 | 08:00 PM
  #73
EVOGOD21's Avatar
3k rpm
Old Mar 7, 2007 | 04:18 PM
  #74
ziggity's Avatar
3000 - 5 or 6000 depending on mood. Typically 4000 on the freeway. If ideal power is right at 6.5 I'll probably try that beyond the first couple shifts.
Old Mar 15, 2007 | 11:08 AM
  #75
stuttgart1's Avatar
A quick question, do you guys shift at redline or shift when you feel the car is not pulling anymore?
