Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
Dead Hooking
Old Feb 22, 2006 | 09:18 AM
IntegxX's Avatar
Dead Hooking
Ive been practicing launching on my stock evo for a couple months now and i find the best way i launch is reving between 4-5 rpms and on the uprev, slipping the clutch. Though this technique works best i burn out for a couple seconds, then take off. Ive seen other evos launch there cars without any burns outs, just straight hooking (dead hooking). I was wonder if anyone knew a technique on how to do that.
Old Feb 22, 2006 | 07:59 PM
chronohunter's Avatar
Originally Posted by IntegxX
(dead hooking).
It that some sort of low budget necrophilia?
to be somewhat productive and not just a smart a** if you want to avoid the wheelspin you have to release the clutch slower and maybe a slightly lower RPM. It's of course harder on your clutch. A little lite wheel spin is good BTW but if you feel the car "sitting there" then that's obviously too much
Old Feb 23, 2006 | 11:37 AM
IntegxX's Avatar
k thanks... ill try slipping at lower rpms and releasing the clutch slower..
Old Feb 23, 2006 | 11:58 AM
Evilution VIII's Avatar
I always aired up my tires a few psi to promote a little bit of wheel spin , just to lessen the shock a little, you could always try going down a little in your case.
Old May 4, 2006 | 11:39 AM
Mitsuzuki's Avatar
Are you practicing lauching the car on the street or at the track? At first, I practiced on the street a few times before going to the drag strip, and the wheels spun nearly every time. With the better/stickier track surface at the dragstrip, I encountered no wheel spin at all with the same launch sequence.
OTRMercuryG
Jun 30, 2016 06:50 AM
Evo_8_REDYG0
Feb 20, 2013 01:03 PM
Johnboy1065
Mar 26, 2008 04:58 PM
Yur
Aug 2, 2006 12:19 AM
3000ways
Aug 24, 2005 08:35 PM
