Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
How to increase the corner entry speed at the end of long straights?
Old Jan 12, 2008 | 01:04 AM
  #61
fastkevin's Avatar
Originally Posted by ROK EVO
1) Do you increase your entry speed by applying 'late-braking' techniques?
The idea is to make the straight as long as possible, and braking later is one way of doing it. There are variables such as the dynamics of the turn following it, and how critical the exit of the turn is to fast lap times( you wouldn't want to sacrifice the turn if it leads to a longer straight, or if it'll screw you for a series of turns)
2) How much does the smoothness (of brake pedal modulation) effect the entry speed? I've noticed that smoother I release my brake pedal, the better balanced car is to take a set. How critical is it to smoothly release the brake pedal?
Pretty critical... Abruptness can upset the chassis,and an upset chassis doesn't like steering inputs,which means you waste time waiting for it to calm down .
3) How can I fix my tendency to over-brake into the corners (at the end of long straights)? Use more of reference points?
Try the "No brake drill" Keith Code (famous motorcycle racing instructor guy) uses it a lot. What you do is leave your vehicle in one gear (4th is a good one for higher average speed tracks), and don't use the brakes. It teaches you a lot of things, some of which is learning that you can usually enter a turn a lot faster than you think, and getting you used to carrying more entry speed.
Old Feb 2, 2008 | 10:27 PM
  #62
mathewpark's Avatar
I don't think we can drive without reference points or 'feel'. We need both of them.
kyoo
1244
Jul 27, 2022 01:02 PM
Evo_Someday
Driving Techniques
Jul 3, 2008 02:13 PM
chronohunter
Jun 14, 2008 08:32 AM
Martin@AMS
May 26, 2008 03:31 PM
playmajohn
May 25, 2008 04:34 PM
