Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
How To Launch The Evo
Old Nov 30, 2011 | 02:10 PM
  #151
solidfish's Avatar
cool
Old Mar 6, 2012 | 11:01 AM
  #152
superkizuna's Avatar
No, it's not survival horror I just got worried about my transfer case after getting addicted to researching mods.
Old Mar 8, 2012 | 07:51 PM
  #153
Mr. Evo X's Avatar
Helpful tips
Old Jul 2, 2012 | 04:14 AM
  #154
Panda_stunter's Avatar
This is how I launched mine
4500 slipping the clutch! Second run, white evo x.
http://www.youtube.com/watch?v=t0XGt...ature=youtu.be
Old Jul 2, 2012 | 11:08 AM
  #155
itsmrrizz2you's Avatar
when i had a stock evo with no 2 step i took it to the track. i was free reving up n down between 5 and 5500 rpm. slipped the clutch out (not dumping it) and it was good enough to get me a 1.68 60ft. not bad for bone stock
Old Jul 4, 2012 | 07:00 AM
  #156
Robevo RS's Avatar
Originally Posted by Raptord
When the car starts inching foward you pull up the e-brake and release the clutch a bit so it isn't dragging. Then you get on the 2-step and you release the e-brake while you're releasing the clutch.
yep, and just 2-3 sec before the actual launch , you need to use a two step. I do turn on the ALS, but you can see the car gets "streched: just about 3 sec before launch.
If you look it very care fully the car rear sits back and stays there, that is when i applyed the E-brake and i am holding back the car with it. Prevent more rolling forward.
aprox around 9 sec in this video you will see what i am talking about
Old Jul 22, 2012 | 05:38 PM
  #157
JaYr_EvO9's Avatar
great tips guy
Old Jul 23, 2012 | 12:35 PM
  #158
Boostin_AWD's Avatar
Coming from a awd dsm to an evo its still the same idea and technique. Slip and grip. Launch rpm is at the digression of the driver. Some people launch at 4500 some at 6000. I personally turned my 2-step up to 5850, same as my dsm. Both use 2600 pp, evo has a street disc, dsm 6-puck. Launching an awd car takes alot of practice. You cant drop the clutch like a fwd, takes lots of power to break all fours loose and even then thats a huge shock on the drivetrain initially. Slipping of the clutch is necessary. Not enough slip, car will bog. Too much slip, you'll burn the clutch. In the end, no one can tell you how to launch your car. Different turbo, transmission, clutch, even engine set-ups will respond differently. Experiment with different rpm's, dont dump the clutch, dont roast the clutch and you'll be ok.
Old Nov 7, 2012 | 07:42 AM
  #159
steffy27's Avatar
I have an evo x and was wondering something about the launch control. Maybe this is a newb question. Are the turbos supposed to spool at all when you use the 2-step? Whenever I hear subis use a launch control or even rev I hear their turbo spooling and then the bov when they let off the throttle.
Old Nov 7, 2012 | 08:20 AM
  #160
Raptord's Avatar
Yes, you will build a couple PSI on the 2-step.
Old Aug 1, 2013 | 02:31 PM
  #161
VinksEvoX's Avatar
This forum makes me very happy. I just bought my evo x last week and have had many questions. All which have been answered from everyone on here. The launch was a big question. Always seemed like my car bogged down as soon as I released the clutch. Thanks for everyones answers, it's helped a lot.
Old Aug 13, 2013 | 08:52 PM
  #162
Ricoswave's Avatar
One of the most overlooked things about launching this car is you have to be confident in what you are doing. If you think in the back of your head for a split second you are going to bog it or burn the **** out of the clutch, you most likely will. Its very unforgiving, but when you get it down there is nothing more rewarding than feeling your soul in the back seat!
Old Sep 15, 2013 | 04:03 PM
  #163
iiEVO's Avatar
Got my launch control set at 6k, once i get my fuel corrected gonna really give launching the car some practice.
Old Sep 16, 2013 | 10:48 AM
  #164
VinksEvoX's Avatar
After some attempts, I eventually got the car to launch. It felt great. Althought I did end up burning the hell out of the clutch. What is the best way to fix that? Or is it just practice?
Old Sep 16, 2013 | 12:28 PM
  #165
Raptord's Avatar
Releasing the clutch too slowly still. After the initial grab, I was almost dumping mine, but above stock power levels you should have enough power off the 2-step to make it slip just enough despite almost dumping it.
(Just to be clear, I was "semi-dumping" the clutch only after it started grabbing, to avoid drivetrain shock.
