Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
How To Launch The Evo
Old Sep 15, 2010 | 07:14 AM
  #121
vince126's Avatar
Originally Posted by brenner
Not me. Ditched it a long time ago
you mention dumping the **** out of it after the grab in your post.
from reading your sig, you mention sheptran. are both your TC and tranny shep? if so yes i would totally dump that **** all the time. Im still on stock tc and tranny, running ACT HDSS clutch, with the clutch pill in, im still a bit scared.
to be honest i haven't launched the car since the tune and clutch install :X
Old Sep 30, 2010 | 08:10 AM
  #122
97EclipseGSX's Avatar
I just read a little bit of this thread and it amazes me at the stupidity in this thread. You all can dump the clutch all you want but you better have a pocket book to cover broken t-cases.
Old Oct 4, 2010 | 09:35 AM
  #123
ODUB's Avatar
Originally Posted by ODUB
Launching is simple.
Step 1: Stop
Step 2: Push in the clutch
Step 3: Put the car in first gear
Step 4: Let the clutch out to find where it engages and hold it just before that (it'll make it easier to slip/dump)
Step 5: Floor the gas, and hold it to the floor. You will start bouncing off the 2-step at 5000rpm and build around 10psi.
Step 6: DO NOT let off the gas pedal at ALL, slip out the clutch until you feel it grab, then let go.
Step 7: DO NOT let off of the gas pedal until you shift to 2nd gear. The gas pedal should be held to the floor from the beginning until you shift to 2nd.
Step 8: Continue shifting gears accordingly.
that's how i've always done it, and it was good enough to get me and my basically stock IX MR to 12.82 @ 107.41 with only a cat back, no tune, no other power adders, a boost leak, and a possibly slipping stock clutch.
This
Old Oct 4, 2010 | 09:58 AM
  #124
Raptord's Avatar
Started re-reading this thread from the top now that I'm starting to launch my Evo. Someone mentioned posting vids of how we launch to see which technique is the best. So, here is a video of my launch (boost gauge wasn't working so ignore that):
http://www.facebook.com/video/video....=1428096580701
I gave just enough throttle to get to 2-step (I have it at 5k). IIRC I was at around 40-45% throttle. I slipped the clutch until the car started lurching forward, then I quickly dropped the rest (not quite a dump, but almost). I waited until the clutch was FULLY engaged before going WOT. The road was moist and I heard the tires chirping a bit. No smelly clutch after the launch either.
Car info:
Stock clutch
~340 WHP/320 WTQ
Comments?
Old Oct 6, 2010 | 06:58 AM
  #125
Robevo RS's Avatar
Originally Posted by Bear.914
DO NOT SIT ON the launch controll for more then a few seconds at most or you will bog out the hole....just another .02cents
if you stay too long on it will not effect on the launch.
This video i do stay long on the two step , waiting the co driver to say "GO" but its not happening , just after a sec or two the a green comes up, she wasnt ready to go. so you see she announce the 5 sec / rev and two step/and then we delay launch after the green light. I didnt know since i do not watch the launch light. I waiting for the "GO" sign. So anyway, because of that i did stay long on the two step and still didnt bug even on steep up hill.
the launch is after 42 sec.
http://www.youtube.com/watch?v=b2Tcb2S0M20
Old Oct 8, 2010 | 09:11 AM
  #126
YuLost2x's Avatar
Google this " launching evos with e-break" you will get a link from evolutionm. Hope that helps out a little.
Old Oct 9, 2010 | 12:36 AM
  #127
quik-viii's Avatar
this is amazing help, I read this and used it at autox, and the last 2 races of the season they started on a nice straight, e-brake launch worked amazing!!!
Old Oct 10, 2010 | 10:19 AM
  #128
YuLost2x's Avatar
Glad to hear. In my opinion ebrake launching is the best and also does the least amount of damage to the drivetrain once u perfect it.
Old Oct 14, 2010 | 07:53 AM
  #129
YuLost2x's Avatar
Went to the track this Tuesday with a couple of my friends. His launch control was set at 6k building 10psi. He was dropping his clutch and actually snapped an axle. I know some people always drop their clutch and nothing happens but I would say do it with caution.
Old Oct 14, 2010 | 03:27 PM
  #130
Robevo RS's Avatar
something always will give...
clutch
tires
or something on the drive train, if you dropp the clutch. Specially on cars with high tq.
Old Oct 15, 2010 | 06:04 AM
  #131
YuLost2x's Avatar
clutch
tires
That is correcto
Old Nov 5, 2010 | 10:55 PM
  #132
tb_evo's Avatar
Step 1: Stop
Best advice here IMHO!
Old Dec 24, 2010 | 06:46 PM
  #133
oximuis's Avatar
well if've tried launching my evo a few times and i really suck at it mind you my evo is bone stock with 41,000 miles. My boy told me that there is nothing wrong with my clutch. Hey maybe my car its just slow. I'm yet to spin the tires.
Old Dec 24, 2010 | 08:54 PM
  #134
Raptord's Avatar
I don't think a stock evo has enough power to spin the tires. Slip the clutch slowly and when it starts grabbing/you start moving forward, quickly release the rest. (Not quite a dump, just a quick release)
Old Dec 25, 2010 | 07:15 AM
  #135
oximuis's Avatar
thanks bro... im on it.
