Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
Shifting to neutral without clutching
Old Jul 31, 2003 | 09:53 PM
NRG's Avatar
NRG
Hey guys, the other day I shifted into neutral without depressing the clutch and it didn't grind or anything. Is this ok? I mean, is it ok to shift to neutral without clutching???
Old Jul 31, 2003 | 09:56 PM
on3ofak1nd's Avatar
yes, but i still clutch /shrug
Old Jul 31, 2003 | 10:20 PM
voodooutt's Avatar
Re: Shifting to neutral without clutching
reason it went into neutral easy and diddnt "pop" without using your clutch 'cuz you matched the RPMs
you can shift with no clutch by this method, but not recommended.
Old Aug 1, 2003 | 03:28 AM
3K's Avatar
3K
The reason it didn't grind is because you didn't put it into any gear. If you would have pulled it (or pushed) any further then it would have made contact with a gear and you would've had that familiar grinding noise.
Old Aug 1, 2003 | 06:06 PM
WestSideBilly's Avatar
El Jefe
This is perfectly ok, though I wouldn't recommend doing it out of 1st gear on most trannies.
weeeeeeeeee
May 17, 2016 01:21 PM
Andrevo
50
Feb 22, 2013 10:40 PM
Betty
13
Nov 27, 2012 11:05 PM
evoTW93
Mar 29, 2010 06:11 PM
EVOL2003
Driving Techniques
28
May 1, 2008 07:05 PM
