Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
Launching
Old Aug 3, 2008 | 05:59 PM
chaotichoax's Avatar
to the OP
search the drag racing sub forum at the bottom of the forum list
Old Aug 3, 2008 | 07:23 PM
EvoJoeIX's Avatar
maybe 05's do then
my buddies doesnt and his is an 05....
Old Aug 4, 2008 | 04:49 PM
96eclipseGST's Avatar
Originally Posted by EvoJoeIX
maybe 05's do then
I thought all 05 and up come factory launch control, I has it
Old Aug 4, 2008 | 05:18 PM
EvoJoeIX's Avatar
weird, maybe his car was flashed and somehow eliminated it or its set real high so it doesnt engage
Old Aug 6, 2008 | 01:10 PM
SLO-EVO's Avatar
Launching for each car is a little different... all you do, if you have 2-step, is:
- press in the clutch at a dead stop
- press on gas while clutch is engaged and car is still at a dead stop
- ease your clutch slightly until you feel your car about to move, we will call that the "sweet spot" (the more you drive your car the better and more fimiliar you will become with the engaging point of the clutch). ease the clutch out a little faster once you hit the "sweet spot"
- if you smell burnt clutch, you didnt ease your foot off of the clutch fast enough... if you bog, you eased off too fast!!!
- PRACTICE!!! its the only way you will be fimiliar with your car!!!
- Once you find the "sweet spot" and learn the speed of easing your clutch out, launch on!!!
*****DISCLAIMER*****
This is how I learned and was taught to launch my car. I am not responsible if you break something because of your attempt to launch your car.
Old Aug 8, 2008 | 03:13 PM
worksevo89's Avatar
Registered User
I drop my clutch at between 5500 and 6000 rpm and i dont bog down, I seem to burn out then go. if i launch any lower i do bog. is this normal?
Old Aug 8, 2008 | 04:01 PM
Audi2ptzero's Avatar
Best way I found to launch any Turbo/AWD car that doesn't use launch control is to just blip the rpms up/down, then go WOT at one of the down sweeps of the tach and release the clutch all at one time at the target rpm. For a GT35r setup thats around 7k. Did it this way in an EVO8 to run low 11's and have been doing it this way in a hand full of A4's and S4's the last 8 years.
Video of me doing clutch drops in my A4 with drag radials, my 60 fts were 1.5-1.6
Old Aug 12, 2008 | 05:09 AM
STIKILLA1084's Avatar
i have a 05 ssl and it did have 2 step but was set up at 4000.
Old Aug 12, 2008 | 05:24 AM
sk8terdude929's Avatar
I have an 03 Evo8 and it came with the factory 2 step
Old Aug 12, 2008 | 05:36 AM
lost spyder's Avatar
I have an 03 evo8 i also have the factory launch control set at the factory 5500rpm. Although i can guarantee the car was reflashed. Why would someone reflash a car and not bump up the 2 step a tad. bogdown central
Old Aug 29, 2008 | 01:48 PM
CrackaBoi's Avatar
So does this not work on the Evo X?
If I have a stock X with a stock clutch, how do I launch it?
Clutch to the floor, rev to about 5k, ease out on clutch until sweet spot, then let go of clutch fast?
Thanks
Old Aug 29, 2008 | 02:23 PM
EvoJoeIX's Avatar
your gonna need a new clutch in no time...
dont practice launches on a stock clutch, you will need a new one shortly after, if not at that moment
Old Aug 29, 2008 | 02:38 PM
CrackaBoi's Avatar
Oh well, so if I wanna get a quick start I'll just find the sweetspot at a high rev (lower than 5k)? I mean there is an optimal way to launch a stock X, I'm asking you what that is.
Old Aug 30, 2008 | 12:18 PM
Evo_Someday's Avatar
My experience is anything less than 5K is going to bog... I would guess that launcing an X would be very similar to any other version of AWD car.
I'd like to see someone try a reverse launch!! hah.
Old Mar 19, 2010 | 01:34 PM
twrx2002's Avatar
hey i just picked up in 08 gsr i noticed it was in launch control mode i searched threw the manual, called dealerships and came up with nothing. can some one please explain to me how to enable the LC and disable the LC on an 2008 gsr 5-speed.
