Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
Launching
Old Apr 7, 2010 | 01:16 AM
  #31
ODUB's Avatar
you can't disable or enable it. it's not so much launch control as a limiter to keep you from destroying your car and mitsu having to pay for it.
to engage it, stop, put the car in 1st gear and floor the gas pedal...below are instructions on how to launch
Launching is simple.
Step 1: Stop
Step 2: Push in the clutch
Step 3: Put the car in first gear
Step 4: Let the clutch out to find where it engages and hold it just before that (it'll make it easier to slip/dump)
Step 5: Floor the gas, and hold it to the floor. You will start bouncing off the 2-step at 5000rpm and build around 10psi.
Step 6: DO NOT let off the gas pedal at ALL, slip out the clutch until you feel it grab, then let go.
Step 7: DO NOT let off of the gas pedal until you shift to 2nd gear. The gas pedal should be held to the floor from the beginning until you shift to 2nd.
Step 8: Continue shifting gears accordingly.
that's how i've always done it, and it was good enough to get me and my basically stock IX MR to 12.82 @ 107.41 with only a cat back, no tune, no other power adders, a boost leak, and a possibly slipping stock clutch.
Jacks Transmissions
Jacks Transmissions
50
Feb 20, 2016 02:54 PM
kdubb03
Driving Techniques
Mar 29, 2010 05:26 PM
TurbotrixRacing
30
Mar 17, 2008 09:06 PM
jesslo
Aug 28, 2004 04:33 AM
NYREDEVO
17
Apr 14, 2004 12:08 PM
