Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
Karts Vs. Cars
Old Jun 3, 2009 | 10:37 AM
adamweldonjohns's Avatar
Karts Vs. Cars
Hello folks,
I've recently had the privledge of driving a race kart at an indoor track and a friend of mine gave me some quick instruction. But here's the question - he was telling me to absolutely crush the brakes REALLY close to turn-in and then to feather the throttle through the slide and power out after the apex. This is totally contrary to what I've experienced and been told at auto-x's - be as smooth as possible, balance the car through the turn, really try not to rotate the car, etc.
How should I be trying to drive these things? Are the kart and the evo really so different they need two different driving styles?
Adam
BTW, I ordered Memo Gidley's karting book so I'll update with some more opinions once I've got it
Old Jun 8, 2009 | 07:43 PM
MitsuJDM's Avatar
Even car to car requires a different driving style. You'd drive an Elise through a corner much different than say a Cobra. Some cars respond differently to different things. Evo's for instance are very sensative to weight transfer (atleast I've noticed). So yeah, cars and karts are probably much different.
Old Jun 16, 2009 | 10:08 AM
Just to update, according to Memo Giddley and Jeff Grist, A kart's ability to turn through a corner relies, in a large part, to the kart's ability to lift the inside rear wheel. They go on to explain that this is due to the fact that karts lack a differential.
Also, the apparent slip angle that I was having to use is due to the fact that indoor tracks (one of which, I was at) are normally slippery. Unless you break the back-end out and use the throttle to steer through the corner, you will not get the inside rear to lift, and will plow through the corner.
Old Jun 16, 2009 | 10:12 AM
Sales@IveyTune's Avatar
Karts are rear wheel drive and rear brake only, totally different beasts. I have found personally that methods in karting differ greatly from front engined all wheel drive cars.
Sam
lexat20's Avatar
In a kart, the brakes are used very little. Most of the braking is done from your turn in.
Old Jun 16, 2009 | 10:29 AM
Depends on the karts.... these ones made 50+ whp and had front and rear disks, but for most of the smaller stuff, I would say 20 whp and less I would agree with you.
Sam
Old Jun 16, 2009 | 10:41 AM
lexat20's Avatar
^^^Also can depend on the track. My local track on a leopard will use the brakes almost zero.
Old Jun 16, 2009 | 09:44 PM
RallyDSM's Avatar
Veteran: Army
Also keep in mind that Karts have an EXTREMELY low center of gravity, extremely tight moment of inertia, ridiculous HP to weight ratio and a rear tire track that is exponentially wider than the front.
ALL of which mean you can do things with a Kart that you CAN NOT do with a car.
For all the discussion, it's really that simple.
Scott
Old Jun 20, 2009 | 01:30 PM
kucaci's Avatar
Scott
Yeah~~That~~
boostincincy
Sep 14, 2015 04:42 PM
bluedub1
North Texas Evo Club (NTEC)
Mar 4, 2015 03:28 PM
David Buschur
Jul 30, 2009 12:50 PM
tc17
Midwest Region
10
Jun 5, 2009 09:19 AM
thestaton
Mid-Atlantic Region
12
Oct 4, 2005 03:28 PM
