Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
what should a good 2 step launch be at???
Old Mar 24, 2010 | 09:12 PM
Rome-Evo's Avatar
i just had my ecu reflashed and it is set at 5812 rpm.. is that good.??
Old Mar 24, 2010 | 09:16 PM
buchnerj's Avatar
You should confine all of these questions to one thread. The 2 step level is driver dependent, really just a personal preference. Mine is set to 4500, but I never launch the car. 5812 is a really random number, why not 5800? Seems a little high, but if you have the drivetrain to back up that beating, why not..
Old Mar 25, 2010 | 10:31 AM
italianevo88's Avatar
^^^^^4500 is a good place to be at if your not a full blown drag strip ****
Old Mar 25, 2010 | 07:25 PM
kouzman's Avatar
5500rpm is the factory guys! why do you want to go less?
i would start at 5800rpm and go from there
Old Mar 28, 2010 | 05:59 PM
codgi's Avatar
5k was stock on the 05s at least from memory but its been a while since I've seen a virgin rom so
Old Mar 31, 2010 | 08:11 AM
evremonde's Avatar
Its also situation dependent. If your doing 1/4 mile launch, you might want it higher for more power. For an auto-x situation you might want it lower, so that the launch is easier to manage.
Old Mar 31, 2010 | 08:20 AM
evremonde's Avatar
the best advice is just to test it. There are alot of variables that could affect the optimal launch rpm. For instance, you cars specific power/torque curve, tires, road conditions, clutch type, car weight ...
Old Apr 1, 2010 | 02:54 PM
cthcky5's Avatar
im set at 5200
Old Apr 1, 2010 | 02:58 PM
BlueEvoG's Avatar
Mine is at the stock rate which is 5500
Old Apr 1, 2010 | 03:01 PM
Teh_Evo's Avatar
Mine is at 6500.
Old Apr 24, 2010 | 02:43 AM
MR. EVO MR's Avatar
Originally Posted by Teh_Evo
Mine is at 6500.
me too
Old Apr 24, 2010 | 02:57 AM
kanyonkid's Avatar
+1, when i used to drag race i would have to adjust it according to the track prep. But i dont that stuff anymore. I think im gonna lower mine to 4500 tho like the guy above said he uses for autox
Old Apr 28, 2010 | 06:09 PM
LaXGSR's Avatar
A related question - what's harder on the car (transmission)? More torque or more horsepower? For example, setting it at 4500 rpm's will yield higher torque but less hp for more cars. 6000 rpm would yield more hp but less torque typically. If I want to be "somewhat" nice to my car, what should I set it at? I was thinking of lowering it from the stock 5500 rpm's, but I'm actually worried that more torque would be worse for the transmission/transfer case/etc.
Old Apr 29, 2010 | 06:29 AM
BlueEvoG's Avatar
Its def torque that is harder on your car than the hp but what were you thinking of setting it at?
Old Apr 29, 2010 | 07:24 AM
LaXGSR's Avatar
I'm open to suggestions Whatever would be easiest on the car for a decent autocross launch.
