Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
Driving on Meth
Old May 24, 2010 | 02:42 PM
05evoGSR's Avatar
my setup starts spraying at 10psi, full spray by 16psi...sometimes i will go a month or more without seeing my green indicator light go on that the pump is spraying. All i have to do is watch my boost gauge and keep it under 10psi which almost always is in normal driving.
Old May 24, 2010 | 04:20 PM
Evoryder's Avatar
^ u need to fix that.
Old May 24, 2010 | 04:24 PM
Boltz.'s Avatar
FCOTM Winner
Originally Posted by MR. EVO MR
Whats the best way to drive on Meth on public roads?
There isn't one. You should never drive on public roads while on meth.
Old May 24, 2010 | 05:19 PM
05evoGSR's Avatar
fix what? If you are tuned for that what is the problem?
Old May 24, 2010 | 05:26 PM
boostedwrx's Avatar
No E85 local? Sorry can't help ya out but thread title was funny
Old May 24, 2010 | 06:22 PM
Evoryder's Avatar
Lets see. If you have a snow kit then the green indicator light is for meth ON. The light is also connected to the 12v output...so you either have a faulty bulb, faulty relay or bad connection somewhere.
If you kit is off and you're tuned aggressive or semi-aggressive then that's a problem
Old May 25, 2010 | 09:53 AM
05evoGSR's Avatar
I didn't really explain what I was saying that well and you read what I was saying wrong. I was saying how diving normally I dont even use a drop of meth for a month or so at a time due to staying out of boost (under 10psi at least). Usually in the winter months when I don't like to get on to much.
Old May 25, 2010 | 10:00 AM
Evoryder's Avatar
my bad.
CopartJohn
E85 / Ethanol
Aug 11, 2016 10:25 AM
nikush
Feb 11, 2015 05:08 PM
Mr. PSSsSt
Oct 19, 2008 09:07 AM
shunderwunder
11
Nov 3, 2007 11:55 PM
MR06Evo
Sep 22, 2007 10:02 PM
