Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
Driving on Meth
Old Apr 17, 2010 | 03:08 AM
MR. EVO MR's Avatar
Driving on Meth
Whats the best way to drive on Meth on public roads?
Old Apr 17, 2010 | 03:44 AM
Tribal's Avatar
well anyone correct me if im wrong but meth doesn't spray until you are WOT. so pretty much what your saying is you want a driving lesson speeding?
Old Apr 17, 2010 | 03:52 AM
Evo8=Life's Avatar
^ i believe thats right or atleast close to right.
Old Apr 17, 2010 | 07:07 AM
MR. EVO MR's Avatar
Not true on my setup all lights turn on even at half throttle when on the highway.
I'm thinking that I need to be in a higher gear to stop the meth from flowing to fast.
Old Apr 17, 2010 | 07:09 AM
wizzo 8's Avatar
drive it like any other car
Old Apr 17, 2010 | 07:14 AM
EVO8LTW's Avatar
Are you running an Aquamist HFS5 or 6? If you were tuned with the turn-on point too low, it will spray in ordinary part throttle driving.
btownsoccer22's Avatar
Meth doesn't spray until you reach a certain PSI. YOu and your tuner set all that up. It's not like meth is constantly spraying. IF your tuner has it set up to spray at say 15psi once you get to 15 psi it will start spraying.
Old Apr 17, 2010 | 07:17 AM
EVO8LTW's Avatar
The Aquamist HFS5/6 generally trigger off injector duty cycle, not boost level. If the turn on point is low, it will spray off boost, particularly in higher gears on the highway.
Old Apr 17, 2010 | 07:41 AM
MR. EVO MR's Avatar
Correct its duty cycle, I'm using hsf3
I guess the duty cycle is set to low, not very streetable,
Old Apr 17, 2010 | 07:50 AM
Evoryder's Avatar
It's kinda hard to avoid the part throttle spray and having a good meth(on) starting point. It's about your driving style. You got to learn to accelerate without increasing load too much.
If you increase your meth start point then it will hit later in your duty cycle = revising your tune. If you have it low(like you do), it will hit sooner and the cooling effects will be much more powerful due to atomization.
Jack of trades had a relay or trigger set from one of the Tephra patches that prevents the meth from coming on until you pass a certain load(200 I believe.) I may incorporate something like that to my setup.
Old Apr 18, 2010 | 04:52 AM
MR. EVO MR's Avatar
im going for a new tune soon, recently installed my fpblack.
should i just tell my Tuner to raise the duty cycle?
Old Apr 18, 2010 | 04:53 AM
MR. EVO MR's Avatar
yes you are 100% WRONG
Old Apr 18, 2010 | 06:28 AM
Evoryder's Avatar
Yes. You should log your car and see when it hits on the hwy and wot.
Old May 24, 2010 | 02:32 PM
squid267's Avatar
hahaha I thought this thread was about another type of "meth"...then I realized what you guys are talking about.
Old May 24, 2010 | 02:38 PM
MR. EVO MR's Avatar
Maybe your in the wrong forum, try meth.com if you have any questions. Lol
