Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
launching
Old Apr 6, 2004 | 11:15 PM
Supa_Kimchee's Avatar
launching
ay yo don't know if this is the right forum, but yea i have an auto 03 oz, and i know that when i drop a auto turbo in mine, if i want a good time, i need a good launch, is the only way neutral dropping? or is there a better way to get more launch from an auto....b/c i heard that neutral dropping is really bad for your transmission... any help?
Old Apr 6, 2004 | 11:18 PM
zlancer's Avatar
definitly don't neutral drop...extreamly bad for the auto tranny. instead just hold the brake down and press on the gas to give the engine a load. then when the light turns green let go of the brake and gas it even more (all the way).
Old Apr 6, 2004 | 11:23 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
I'm gonna move this to driving techniques. There are a couple of threads in there about launching, but I don't think any of them address auto transmissions. But I'll second the idea that you don't want to neutral drop. I like the suggestion posted above, although you should technically be letting off the brake and hitting the gas at the 3rd yellow (something I learned after getting a bunch of 1.1+ reaction times my first time out).
Also, a limited slip differential would be a good idea, if it works with an auto. Otherwise, you're still likely to slip one wheel while the other tries to propel the car forward.
