Driving Techniques Discuss things like how to launch your car, or turn in points, correct steering position, etc.
1/4 Racing Techniques
Old Mar 21, 2004 | 08:35 PM
I REP 838's Avatar
For those of you who are experienced with 1/4 mile racing what would you suggest to get the best time you can with your vehicle? Shift right at redline? Keep the gas down and do what some would call a "powershift"? I'm just curious. There's alot of little things you can do to make your 1/4 mile times a little bit better and I was just curious what you experienced drivers would suggest? I've been racing on the streets for awhile. I've finally came to my senses and I'm new to the LEGAL races at the track we have here in Sacramento. I'm just curious on some advice on racing techniques that will give me those faster times I'm looking for. Or maybe everything I'm doing is already good enough. Let's get some good advice from those of you who have tested many techniques on the tracks
Old Mar 21, 2004 | 08:51 PM
MitsuRalliArt's Avatar
1. Shift at peak power
2. Feather clutch at launch until the wheels are hooked at WOT This is so you don't bog down the engine
3. Practice sifting faster
4. Loose all un-needed weight
5. Powershifting is heavily debated. It is simply not lifting throttle between shifts. Try both ways and see what works best for you.
6. Loose the all season tires
Old Mar 26, 2004 | 01:57 AM
lucky31337's Avatar
After the launch it is essential to have the quickest possible 1-2 shift that you can have with your clutch not slipping. This allows you to reduce your 1/8 mi times while at the same time getting to the 60' marker quicker. I like to powershift my vr-4 whenever possible, but right now my RPS pressure plate failed so Im getting soemthing else. Also keeping the throttle floored negates the neccessity for the turbo to have to "respool".
Old Apr 11, 2004 | 12:58 AM
TypeIII's Avatar
What was your 60' time, and what tires were you using?
Old Apr 11, 2004 | 01:10 AM
alex_alex's Avatar
I disagree.
1. Power really has little to do with acceleration, let alone peak power. Some other concerns are how much the power actually drops after peak, and where your 1-2 shift will put you rpm-wise once you're in second
KK
Driving Techniques
115
Jul 6, 2017 11:04 PM
LandoCommando
Aug 21, 2012 09:00 PM
MrBonus
10
Feb 3, 2010 08:18 AM
krisdlm
Mar 26, 2009 05:07 PM
JdmSyndicate
Dec 1, 2008 09:01 AM
