DynoFlash [Visit Site]
New Dual Stage Buschur Flash ! Race gas and pump gas tunes on same ecu.
Old Oct 1, 2004 | 10:05 AM
  #31
chickenbrest's Avatar
That is totally awesome. How about a 91 octane/race gas dual flash on one and a pure race gas flash on the other. Is that an option? That way I can have the best of both...
thanks again,
-Doug
Old Oct 1, 2004 | 10:59 AM
  #32
BMWE30's Avatar
AL,
I just bought all these goodies and have to install them now how much more pwr will i make with your tune over the tune that Buschur gave me for there SAFC2?
MODS to be installed:
BR intake
BR MAF pipe
BR Upper IC pipe with 1G BOV
BR Mini Battery
BR SAFC 2 w/ BR settings
Ultimate racing turbo back with Test pipe
Excedy Twin Disc Clutch (AL where do i get this install the cheapest!)
Hallman MBC
Walbro 255lb
Also how did Buscher racing get 343WHP out of there Stage 2 car with the SAFC?
Quote from BR site:
"Once you've completed Stage 1, you will be approaching 300whp. In Stage 2, we further improve the flow of the charge air into the engine. By optimizing the airflow into the turbocharger and eliminating the flow restrictions in the upper intercooler plumbing, we have been able to push our EVO to 343whp at the same 19psi boost level used in Stage 1. Our upper intercooler pipe upgrade eliminates 6 bends and 16 inches of length. Because the flowpath of the pipe was so important, it necessitated a solution to relocate the battery. This has been resolved with our battery kit. Looking at the intake hose from the mass air pipe to the turbo, it was apparent to us that improvements could be made. To this end we have developed a smooth flowing 3" intake pipe. These Stage 2 modifications were developed with our future modifications in mind. For example, we designed the upper intercooler pipe kit to work with our upgraded front mount intercooler kit so that you would not be forced to repurchase parts that you've already upgraded. "
Old Oct 11, 2004 | 10:06 AM
  #33
number 8's Avatar
Al, I'm planning on bringing C16 for the race fuel duel flash when you're back in Chicago. Sounds like I can get away with leaded fuel for a while. But, if the O2 sensor goes, what kind of replace/repair costs are to be expected?
Old Oct 11, 2004 | 11:29 AM
  #34
DynoFlash's Avatar
Originally Posted by BMWE30
AL,
BR intake
BR MAF pipe
BR Mini Battery
Hallman MBC
Walbro 255lb
Quote from BR site:
With tha flash the gains will be more on driveability - smopothness and increased tq down low
I think you can make just as much peak whp with the AFC as you can with the reflash - its just that the flash does a better job
  #35
DynoFlash's Avatar
I think the o2 sesnor - the fornt one is over $200 for replacement - but i have no exact idea
Old Oct 20, 2004 | 07:39 PM
  #36
ctevo's Avatar
Al I am planning on getting some work done at Pruven soon, new cams,headstuds, injectors, cat delete, etc.... I have a custom tune by u and am going to want to have another tune done by u as well and I'm very interested as to whut I would need to run this dual stage flash. I am planning on running at the Oct31 shoot out at englishtown and so I want a race tune as well as a street gas tune. Do I need a second ECU for this or do u somehow set up the original one to be able to switch between a street and race tune map depending on the boost it sees or how ever u set it up? Lookin to join the 11 second Dynoflash club once I get it tuned for 100 octane and run at englishtown.
thanks
Old Oct 20, 2004 | 08:05 PM
  #37
DynoFlash's Avatar
thanks
Dual stage uses one ecu. I an explain more on how it works when I see you.
Call me at 203-515-4110 and we can discuss your planned mods and a appointment time for next week
Old Oct 21, 2004 | 09:03 AM
  #38
gsujeff55's Avatar
is there still no dual stage on through the mail flashes? do we have to have the exact buschur stage 2 mods, or can you do a dual stage with mods we list?
Old Oct 26, 2004 | 11:30 PM
  #39
Zeus's Avatar
Very interesting... I'm wondering if you are using the OE "fail safe" map as a primary in this set up though...
Old Oct 27, 2004 | 06:22 AM
  #40
DynoFlash's Avatar
Interesting indeed ! When i get down there to Texas I'll be happy to give you a demonstration first hand of Dyno Flash power !!!!!!! (Its no accident that I am the only reflash tuner with Evos running 11's second passes - 10 of them as of now)
Old Oct 27, 2004 | 07:42 AM
  #41
Zeus's Avatar
To answer my question though, are we losing a safety net? What happens when you get a bad tanks of gas? What map does the ECU fall back on? Or can it?
Old Oct 27, 2004 | 07:44 AM
  #42
Zeus's Avatar
PS, I might be interested in that demo...
Old Oct 27, 2004 | 10:48 AM
  #43
DynoFlash's Avatar
With the dual stage flash - the only changes are made to the load reference in the bottom line of the tuning map which you should never reach in any event below 22 psi. We create the additional tune in that area
The knock protection and dual mapping features continue as stock
The only difference is IF you hit high boost over 23 psi then you will be on the more agressive settings
As posted in earlier posts - this is best advised with a electric boost controller with warning function to prevent against accidental over boosts
