DynoFlash [Visit Site]
What mods are safe without a flash
Old Nov 5, 2004 | 10:26 PM
bracer's Avatar
Removed
Old Nov 5, 2004 | 10:27 PM
Sentinal's Avatar
air filter and exhaust should be safe I would deffinately wait for the cams and fuel pump
Old Nov 5, 2004 | 10:45 PM
DynoFlash's Avatar
I would leave the air intake stock for now
You can get away with the exhuast and MBC with no problem
BTW - the '05 flash will be ready very soon - prob within 10 days
Old Nov 7, 2004 | 11:18 PM
Corey's Avatar
Al suggests at least 660 injectors too when going with cams. I found that out yesterday. I'll be getting them from Al real soon.
Old Nov 8, 2004 | 07:24 AM
DynoFlash's Avatar
With the following intakes - Injen, APS and HKS RS. The reason is related to the unique way those intakes distort the MAF sesnor reading through the middle of the power band.
Old Nov 8, 2004 | 12:33 PM
Corey's Avatar
Ah.....I see. Thanks.
Old Nov 8, 2004 | 01:59 PM
brandon's Avatar
Al, so you only need the injectors if you are also using one of the above mentioned intakes when upgrading to cams?
Old Nov 8, 2004 | 04:25 PM
DynoFlash's Avatar
Even in the case of those intakes - the injectors are optional, the stock ones will support up to 340 - 350 whp. However, pushing injectors to 100% duty cycle is not prudent. I recomend the 660 to 680 injectors on cars with intakes and cams - it makes for a larger margin of saftey with more conservative injector duty cycles.
Old Nov 8, 2004 | 04:27 PM
steveevo8's Avatar
is tehre any need to worry if i'm gona run a full 3" catless exhaust without a reflash???
Old Nov 8, 2004 | 04:33 PM
DynoFlash's Avatar
No need to worry of course it will run fine.
As with a regular stock evo, however, with performance mapping in the ecu you will gain additional power and smoothness over the stock ecu mapping
I would hazzard to say that your $199 spent on a reflash will make you more whp than $1000 spent on an exhaust.
Of course the best approach is a boost controller, exhuast, and flash
Old Nov 8, 2004 | 04:37 PM
steveevo8's Avatar
yeah well i'm kinda doing the exhaust first cause of money situation. i'm gettin a full UR TBE for 450, so i'm gonan jump on that.. instead of paying 700+ for a helix.. i hope to get a boost controller for christmas , compliments of my gf, but what boost contorller would you reccoment.. i live in Pittsburgh. and i understand you have to change it often cause of the weather change... what is the easiest way for me??
Old Nov 8, 2004 | 05:47 PM
DynoFlash's Avatar
Hallman MBC
They need very seldom adjustment
I sell them for $90
Or you can get the evolution Hallman with in car controller for $160
