DynoFlash [Visit Site]
base flash wtih hks rs intake how much boost?
Old Dec 15, 2004 | 01:06 PM
ctx2000's Avatar
hai AL.............i got base flash with walbro fuel pump, 3'' turboback with test pipe, hks rs intake, hks evc v, ralliart spark plug, hks ground wire kits, UR intercooler hardpipe(upper and lower).............howmuch boost can i run?
is it save if i turn the boost to 74 it's about 20-20.5psi
Old Dec 15, 2004 | 01:18 PM
nick735's Avatar
i have a turboback and hks intake and I have the boost set at 1.4 bar, which is roughly 20.5 psi.
Old Dec 15, 2004 | 04:23 PM
DynoFlash's Avatar
20.5 peak is what I recomend
A customer of mine who pushed it to 22 psi cracked his piston in half last week
20.5 is the safe limit on pump case
Old Dec 16, 2004 | 12:15 PM
ctx2000's Avatar
if i used hks evc v howmuch do i have to turn it to...to get to 20.5 psi
and howmuch do i have to turn it to get 19/19.5 psi?
Old Dec 16, 2004 | 12:24 PM
DynoFlash's Avatar
You simply turn up and down the knob till it makes the desired boost target on your boost gaguge
Old Dec 16, 2004 | 08:06 PM
ctx2000's Avatar
hai AL here is another question.........set A is 70 ( i don't know howmuch psi )
Old Dec 16, 2004 | 08:07 PM
ctx2000's Avatar
you set my hks evc v as set A is 70 and set B is 94............can you tell me approximatly howmuch psi this is?
Old Dec 16, 2004 | 09:00 PM
DynoFlash's Avatar
no - it varies from car to car - get a boost gauge
Old Dec 17, 2004 | 12:19 AM
SubiEvolved's Avatar
ive been driving around with 22 peak boost. you think i should lower it al?
ERIK
