DynoFlash [Visit Site]
Help!!!!!!!
Old Jan 10, 2005 | 04:58 PM
go2evo's Avatar
Question Help!!!!!!!
my car only has dynoflash,
i want to set boost at 20 psi
DO I NEED A RE-FLASH OR A WALBRO FUEL PUMP????
Old Jan 10, 2005 | 06:07 PM
DynoFlash's Avatar
no - but it wouldn't hurt you to get a walbro pump and a reflash, just for peace of mind
Old Jan 11, 2005 | 10:15 AM
go2evo's Avatar
thanks alot al
Old Jan 12, 2005 | 12:48 PM
go2evo's Avatar
is it safe for daily drive, AL?????
Old Jan 12, 2005 | 03:52 PM
DynoFlash's Avatar
yes
Old Jan 13, 2005 | 11:52 PM
go2evo's Avatar
awesome, your da man
Old Jan 14, 2005 | 07:14 AM
TC4G63's Avatar
what kind of fuel are you using? 20psi seems to be a psi too high on 91 octane, i wouldn't go over 19 on that **** water.
Old Jan 14, 2005 | 06:17 PM
fre's Avatar
fre
You can run more boost, but the car will just pull timing and you will end up making less power. Power = max boost your car will run without pulling timing. Like I could run 25 psi and make around 380 hp but it would pull timing after one run. 19 psi on 91 octane sound about right. I run between 19 and 21, but it still pulls timing depending on how hot the car is.
Old Jan 14, 2005 | 07:22 PM
housedj's Avatar
Thumbs up
i would probably run 2 or 3 gallons of at least 100 octane w/the 91 so timing won't pull as much. it might be better on your motor. unless you like replacing things...
Old Jan 14, 2005 | 10:23 PM
go2evo's Avatar
thank you guys, really appreciate all your 2 cents
what is pull timing??
Old Sep 7, 2005 | 03:48 PM
go2evo's Avatar
BUMP i want to know what's pull timing!!!!!!!!!!!!!!
Old Sep 7, 2005 | 03:54 PM
platinumspecv's Avatar
im surprised you dont have a walbro pump already..should be your first mod
Old Sep 7, 2005 | 03:55 PM
05WhiteEVO8's Avatar
Do a search man, basically timing is what keeps your motor safe, how far it advances it = more power but the stock ECU will pull it away if it detects knock.
Old Sep 7, 2005 | 03:57 PM
When your knock sensor senses some knock activity it tells your ECU to retard ignition timing. It's there to save ur motor
Old Sep 7, 2005 | 04:59 PM
go2evo's Avatar
still don't get it, how can i tell if time pull or not?
