DynoFlash [Visit Site]
whats it going to take to beat my buds STI with COBB stage 2
Old Feb 12, 2005 | 07:58 PM
schumi's Avatar
guys killing me.
Old Feb 12, 2005 | 08:14 PM
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
What does he run in the 1/4? I've seen Cobb numbers all over the place.
Old Feb 13, 2005 | 02:32 AM
schumi's Avatar
He runs a 13.2 103 I just ran tonight best was 13.8 100.00 clutch was slipping so bad I decided not to run the rest of the night. Oh my 60 ft was 2.00 with massive clutch slip.Not good.
Old Feb 13, 2005 | 02:39 AM
r8c3w1tm3's Avatar
intake, dp, cat delete, exhaust....
Old Feb 13, 2005 | 02:40 AM
Lowness's Avatar
Are you stock?
A mail-in flash and MBC should help you beat him. Turboback and test pipe if you have the money.
Old Feb 13, 2005 | 02:44 AM
evoate's Avatar
I would say a new clutch should be on that list too.
Old Feb 13, 2005 | 04:59 AM
schumi's Avatar
I would say a new clutch should be on that list too.I cant belive how week the stock clutch is.I have less than 5000.ml on the car it is the first time I have driven it that hard. I have a tbe and the mail in reflash.
Old Feb 13, 2005 | 05:31 AM
mr96gsx408's Avatar
get a STI with a with COBB stage 40xinfiniti . you'll definately beat him with that...
get your launch down first thing. with sti's you just drop the clutch. my friend launched his evo RS hard and because he burned it slightly on the launch, it slipped the rest of the gears down the track resulting in high 13's like your times.
I got a 1.8x 60' on my way back when it was gsx stock so try harder...
Old Feb 13, 2005 | 06:05 AM
SterlingEvo's Avatar
Definitely anything comparable to Buschur stage 1. Exhaust, boost control, and good tuning and you'll be running high 12's (I ran 12.8 like that...). Oh yeah, and a better clutch
Old Feb 13, 2005 | 10:14 AM
I ran at 12.6 at 109 with K&N cone intake, MBC, HKS DP and HI Power exhaust and Power FC. I have over 30,000 miles and 3 trips to the track, all on the stock clutch.
Old Feb 13, 2005 | 01:29 PM
schumi's Avatar
ok please tell me how you guys are getting 1.8 or lower on the stock clutch with out it slipping. I am not being sarcastic.
Old Feb 13, 2005 | 05:55 PM
I rev to 5,000 rpms and quickly slip the clutch. Once and a while if I slip it too long, I'll smell it after the run. My 60 ft was right at 1.8 IIRC. I'm sure I could get lower with a more aggressive launch, but it is the stock clutch.
Old Feb 13, 2005 | 07:54 PM
schumi's Avatar
I rev to 5,000 rpms and quickly slip the clutch. Once and a while if I slip it too long, I'll smell it after the run. My 60 ft was right at 1.8 IIRC. I'm sure I could get lower with a more aggressive launch, but it is the stock clutch. Thats what I did only the car reved to 7500 only the tires were not spining the clutch was then it went.
Old Feb 13, 2005 | 09:05 PM
AdamsssEvo's Avatar
try bliping the throttle around 5500 to 6500. On the 3 or 4 blip do a quick slip. Do not ride the clutch out
Old Feb 14, 2005 | 07:37 AM
My 1.7's were all on aftermarket clutch...
