Tales of the Dyno - Buschur Stage 4
Originally Posted by DynoFlash
Thbis tune was set up differently as Mark is an auo crosser - peak numbers are a bit higher as a result than a typical street driver
Originally Posted by EVO8LTW
Could you explain that a little more? I was thinking that autocross would require a more conservative tune and therefore peak numbers would be lower. Sounds like you are saying the reverse, unless you mistyped.
Basically, when tuning we listen to our customer about how they feel about saftey vs. performance and also the kind of driving they will do.
Al-- Do you do your custom tunes any differently for someone who is going to run sustained high RPMs in autocrossing like Mark, versus someone that is mainly interested in brief blasts of max power on the street or 12 seconds at a time (1/4 mile)?
Originally Posted by EVOMIZ
so al how long is the alcohol lasting ?
anyone know exactly how long you can run until it need a refull?
I think we are looking at 2 tanks of gas to the gallon of alcohol - depending on how often you boost
