DynoFlash [Visit Site]
Al, how much to adjust fuel trims?
Old Apr 11, 2005 | 05:41 PM
TrinaBabe's Avatar
Hey Al, I wondering how much you would charge if at all possible to JUST change the fuel trims so be leaned out 30% or so. My AFC is at -30% pretty much across the board... I am thinking that this is screwing my timing all up for the car. Is it possible to JUST modify the fuel so that it pretty much compensates for my larger injectors? How much would that cost? I can send you the ECU pronto after you let me know. Thanks! You could also just call me if you want at 608-628-0254
-Katrina Kujak or Tim Russell
Old Apr 11, 2005 | 07:10 PM
DynoFlash's Avatar
I can do that - $79.99
I would suggest the regular dyno flash tuned for your mods and fine tune with SAFC at $199 though
Let me know
Old Apr 11, 2005 | 08:13 PM
TrinaBabe's Avatar
I would like to get it custom reflashed... Im not sure if you would have any maps for my car. You very well may though... here is the list of parts. Let me know what you think you could do for me.. Right now my problem is the AFC being that lean HAS to be destroying the timing table. Here is a list of the parts...
Magnus Intake Manifold, Buschur Upper/Lower IC pipe, HKS BOV, Walbro 255, 780cc Injectors, Shearer exhaust headers, Shearer o2 housing, Tial 44mm wastegate (Externally dumped), Buschur Front Mount, ACT 2900, GT 35R, 3" full TBE, no cat, S-AFC, HKS 272/272, Aeromotive Fuel Pressure Regulator, Stock Block, Stock Head (Aside from Cams).
I already had you reflash to car to remove the fuel cut and raise the rev limiter. I guess I would like to win your prize for the first in the 10's if that is still out there. Thanks and let me know what we can do.
Old Apr 11, 2005 | 08:45 PM
TrinaBabe's Avatar
I think it may be better for you to give me a call when you get the chance. I have some ideas that may be helpful for both of us. Heres my number again
Katrina Kuajak or Tim Russell
608-628-0254
Fast_Freddie
Oct 30, 2023 01:56 AM
gMouss77
Apr 21, 2015 10:46 AM
.MM
33
Sep 21, 2007 12:34 PM
AOR
13
Aug 25, 2006 11:39 AM
Rob W.
Aug 23, 2006 12:11 PM
