DynoFlash [Visit Site]
Custom tune question
Old May 21, 2005 | 04:43 AM
crow's Avatar
Hey Al,
I have a custom tune right now from you. I am installing some new parts and wanted to know if I need a new tune or just a flash upgrade. The new parts I am installing are: 272/264 gsc cams, 6.5 rs tme turbo, helix o2 housing, pro1 manifold and a fuel pressure regulator w/ gauge. If I need a new tune, when are you availible. Also what psi should i set the fuel to on the regulator?
Thank's Al
Chris
Old May 21, 2005 | 05:37 AM
tcarretti's Avatar
Sounds like you're going to need a custom tune dude. That's A LOT of extra goodies and to extract the most power safely out of those it would be best to have either a custom road/dyno tune.
Should be a real kick in the pants when you get it done though..... good luck!
Old May 21, 2005 | 09:15 AM
qbbraveheart's Avatar
definitely get it re-custom tuned
Old May 21, 2005 | 09:37 AM
evo_dadi's Avatar
damn good mods there buddy custom tune will definitely give you a kick in the nut.
Old May 21, 2005 | 07:52 PM
crow's Avatar
I hope so.
Does anybody know what psi the fuel should be set at?
Old May 21, 2005 | 08:04 PM
Grod101's Avatar
why are you putting a fuel reg on there are you going to be adding more mods in the future like a big turbo kit?
Old May 21, 2005 | 08:45 PM
crow's Avatar
because the stock reg does not keep up with the increase of boost on a 1:1 ratio
Old May 23, 2005 | 04:23 AM
crow's Avatar
does anybody know what psi the fuel pressure should be set at?
Old May 23, 2005 | 04:46 AM
2literv8eater's Avatar
I would say whatever the stock PSI is, on a 2G Eclipse it's around 41 PSI at idle. Sorry not sure what the EVO stock is.
Old May 26, 2005 | 07:14 PM
crow's Avatar
Hey al,
When will you be around to do a new custom tune on my car with the new mods above? What should I set the fuel pressure to?
krnzzang84720
Lancer Aftermarket Forced Induction Tech
74
Jul 9, 2007 06:44 AM
Jrod@Buschur
58
Jan 29, 2007 09:33 AM
spak920
61
Nov 20, 2006 10:52 AM
