DynoFlash [Visit Site]
Dyno Flash ecu EZ
Old Oct 20, 2005 | 09:30 AM
coffeeslug's Avatar
Dyno Flash ecu EZ
I read a post about this here: https://www.evolutionm.net/forums/sh...d.php?t=125545
"the Dyno Flash ecu EZ - you will get a stock flash - pump gas flash and race gas flash along with a device to flash in those three anytime you want"
Did this project get scrapped, or is it still in the works?
Old Oct 20, 2005 | 09:35 AM
Ev0ikon's Avatar
It is done and it works. You should PM Al/Dynoflash if you want details.
Old Oct 20, 2005 | 09:43 AM
justchil's Avatar
I never knew about this.. also might be interested..
Old Oct 20, 2005 | 11:30 AM
DynoFlash's Avatar
I have two seperate variations on this
1 - is the so called "dual stage flash" which runs one tuning calibration for low octane pump gas and a more agressive setting when you turn up the boost - its automatic and works very well. Its free with any flash.
2 - The Dyno Flash "EZ" is still several months away. It will be Ecutek based, and Ecutek is running behind scedule.
I will post more details when its closer to release
Old Oct 20, 2005 | 11:35 AM
fury656's Avatar
Very good news there, I guess Ecutek finally got something similar to Delta Dash running on the EVO.
Old Oct 20, 2005 | 11:51 AM
DynoFlash's Avatar
Delta dash would be impossible on an evo due to the slow OBDII interphase rate comapred to subaru.
This will be a different type of product.
Again no date even on the horizon
Old Oct 20, 2005 | 12:05 PM
justchil's Avatar
I'll definately have to get this once the 20G is in
Old Oct 20, 2005 | 05:59 PM
AutoXer's Avatar
I hope it doesn't turn out to be "vaporware." They said something about changing all the dealers interface cables and running them through their paces first... or something like that. I read that on www.ecutek.com forums. You guys should go over there and voice your desires to them.
Steve@WORKS
Lancer Engine Management / Tuning Forums
112
May 20, 2009 08:25 AM
Jim in Tucson
E85 / Ethanol
43
Jul 31, 2008 06:27 PM
riceball777
41
Feb 6, 2007 07:14 AM
carbonevo8
Northwest Region
41
Feb 24, 2006 05:22 PM
ozmaster
22
Mar 16, 2005 06:10 AM
