DynoFlash [Visit Site]
Which plugs to use?
Old Oct 26, 2005 | 08:56 AM
Corey's Avatar
Which plugs to use?
Since Al has tuned my car, I figure I'd ask him which plugs to use. Mods are:
HKS rs intake
HKS turbo exhaust
HKS 264's
Walbro
Perrin cat delete
Custom reflash
I have the bpr7es in my car now, but after reading a little I don't know if I need to do the br7es or the br8es. I'm getting a misfire code so I figure I'll change my plugs.
Which one do you recommend Al?
Old Oct 26, 2005 | 09:24 AM
justchil's Avatar
BPR7ES is what you want.. I've been getting misfire codes after my flash as well :x
Old Oct 26, 2005 | 10:32 AM
Corey's Avatar
Could anyone tell me the advantages or disadvantages between the BPR7ES, BR7ES, BPR8ES, and the BR8ES? I seen people running these plugs the most and was just wondering what it would do to my car if I went to the 8.
Old Oct 26, 2005 | 10:37 AM
Silver05Bullet's Avatar
Go with the BPR8ES gapped at .20-.22 should make your car run good and no more misfires.
4-BNGR's Avatar
gap your plugs to 0.26. they do not come pre-gapped...
Old Oct 26, 2005 | 10:38 AM
justchil's Avatar
I think the BR#ES's don't have the protruding electrode.. not really sure what that means exactly..
The BPR8ES is a colder plug.. Might be good if you're running high boost.. I've tried these but I got a lot of misfire with 20psi on pump gas.
Old Oct 26, 2005 | 10:39 AM
justchil's Avatar
I thought they normally come gapped to .032? I always gap mine .025-.026
Old Oct 26, 2005 | 01:30 PM
beavis4g63t's Avatar
P= protruded nose
R= resistor type
7= factory heat range
8= one step colder
Old Oct 26, 2005 | 01:50 PM
naucrx's Avatar
I've got basically a Buschur Stage4 + EMS with BPR7ES plugs gapped at .026, no misfires.
Edit: Forgot to add that you'll need to replace the BPR7ES plugs a lot more often than the stock Iridium plugs. If it's been longer than 3 months you might just need some new plugs.
Old Oct 26, 2005 | 03:07 PM
revhappy's Avatar
Also interested in this, and also the time/mileage intervals for changing each.
Old Oct 26, 2005 | 03:21 PM
ap-evo83's Avatar
From: RAMAR village, pampanga PHILIPPINES, Temecula, CA
nice info
Old Oct 26, 2005 | 03:54 PM
GBEvo's Avatar
I've got the BPR8ES gapped to .25 and no misfires.
Old Oct 26, 2005 | 04:24 PM
eve-slow's Avatar
I believe that Al recommends BR7ES's gapped @ 24.
Old Oct 27, 2005 | 05:47 PM
DrBump471's Avatar
BR8ES gapped @ .24~.25 (no misfires)
Blitz SUS Intake, TBE (+ UR High Flow Cat + Helix O2 Housing), Walbro 255 Fuel Pump, HKS 272/272, ARP Headbolts, SMC Methanol Injection, Al Tuned
Haven't had a misfire since I put them in [knock on wood]
I would stick with the 7's for your mods but purchase both the BPR and BR's and see what you like. (they are only 1.89 a piece or so)
Old Oct 27, 2005 | 10:29 PM
Corey's Avatar
I'm waiting for Al to chime in.
So the protruding nose is good if you run high boost or is it the other way around? I run nothing but 93 in my car and it will ocasionally spike to 22 psi.
I've had the BPR7ES's in my car for about 8,000 miles or maybe a little more. I don't mind changing them out often, but if I can get a plug that will last longer and make my car run better I would rather have a different plug.
Thanks for the help everyone.
