DynoFlash [Visit Site]
Al, Question after custom tune ??
Old Nov 21, 2005 | 11:36 AM
espritv8's Avatar
Al, I had you do the custom tune on my 03 at the Charlotte location. You set it up for road racing and on the safe side. I just got back from an event this weekend at VIR and noticed that after making a turn and getting back on throttle I would have a lot of smoke from the exhaust. It looked more like fuel than oil. The people who were running with me said that I was blowing flames " Looked cool". Is this normal since I had you tune on the safe side? Also just to note that I was running 100 octane... Thanks
Old Nov 21, 2005 | 11:40 AM
justchil's Avatar
You probably need to turn the boost up with 100 octane... If you were tuned on 93 and just throw 100 in you will be running rich.
Old Nov 21, 2005 | 11:44 AM
espritv8's Avatar
I wasnt quite sure how far to safely go with the boost level. I was jumping to 24 out of the turns then holding at 22. But I assume that either way the running on the rich side is a better safety margin.... As long as its causing no issues..
Bimmubishi's Avatar
that is not good advice.
Old Nov 21, 2005 | 11:49 AM
espritv8's Avatar
The turning up of the boost?
Old Nov 21, 2005 | 11:53 AM
justchil's Avatar
Take it as you wish.. but putting 100 octane in a car that was tuned for 93 is just going to make it even more rich. I was tuned for 22psi on pump 93.. I run 24/25psi peak with 100 octane in.
I wouldn't go too crazy if you don't have means of monitoring your AFR. I was talking like 1-2psi.
Old Nov 21, 2005 | 12:01 PM
espritv8's Avatar
Thanks, I like going more for safety than all out power. I run 4-20min sessions each day.
Old Nov 21, 2005 | 03:37 PM
DynoFlash's Avatar
When you are doing road racing the coolant temps get very hot and the ecu adds in additional collant temp enrichment corection
The car will run a bit on the rich side
However - this is very safe and your car will last with no problems
For those who do not drive the car every day I have ways to map the car so the a/f stays more lean in a racing situation and will make more power - however this is not recoemnded for street cars that run pump gas
USING ONE MAP for street and race involves some compromise - here is is a few whp and being a bit on the rich side
Old Nov 21, 2005 | 03:40 PM
superflyevo's Avatar
runing too rich
Old Nov 21, 2005 | 04:25 PM
espritv8's Avatar
Thanks Al, I dont mind losing a few whp for the comfort of knowing that its safer.... Thanks again for the custom tune!!! Ran great
