DynoFlash [Visit Site]
Alky Kit Just For The Track?
Old Nov 24, 2005 | 11:38 PM
yellowgsr's Avatar
Hey Al or anybody that has a good idea.I'll be getting an alky kit and your custume tune once you get to colorado.Can i still get a good street tune with 100%alky,if I'm only planing on spray at the track and maybe sometimes on the street?
THANKS.
Old Nov 25, 2005 | 12:53 AM
fromWRXtoEVO's Avatar
I think you are in the same boat as me. I will be tuned by Al in a few days, I am getting the SMC kit and I want to be able to use the alcohol kit ocasionally on the road and asll the times at the track.
Don't worry that Al knows what he is doing. He will probably set your alcohol injection engaging at high boost so that you don't have to use it consistently in traffic etc.
Old Nov 25, 2005 | 05:49 AM
vrrrm...psss's Avatar
THANKS.
Like what the other guy said, the SMC kit has a progressive controller that will allow you to begin spray at 16 psi, and max out at 26 psi. If you can keep your foot out of the gas pedal on the street, you wont hit 16 psi, and you wont spray. Im not exactly sure why you would not want it to spray on the street however.............are you afraid of wasting the meth?
Old Nov 25, 2005 | 08:44 AM
cfdfireman1's Avatar
Like he said.
That's exactly how mine is set up. Starts at 16 maxes at 26.
You can go for days without using any spray if you can keep your foot out of it. Physically easy, psychologically close to impossible!!
Old Nov 25, 2005 | 08:47 AM
soundfx007's Avatar
Waste meth? Ha, that stuffs about 1.50 a gallon and only lasts couple weeks weeks. Thats gotta be about 36$ a year. I cant afford it either.
Old Nov 25, 2005 | 08:58 AM
yellowgsr's Avatar
Thats right,will be impossible for me not to boost,it's just a matter of being cautious,I've herd couple of horror stories were the the pump wasn't pumping the preciuos juice,even though the light was on,the other thing is engine longivity,i just dont want to rely on chemical cooler all the time,until the system is 100%safe or i have the money to buy all the gadgets to monitor whats going on
Old Nov 25, 2005 | 09:01 AM
DynoFlash's Avatar
Trust me - once you try the alochol on your car you will want it on all the time
Old Nov 25, 2005 | 09:09 AM
yellowgsr's Avatar
I know!!
Old Nov 25, 2005 | 10:48 PM
sleet's Avatar
It's 1.5 a gallon?
Old Nov 25, 2005 | 11:01 PM
scorke's Avatar
I was thinking of doing something like this for road racing as a sort of safety measure. If you had some way to use boost level or knock readings as parameters for an alk system running just to make sure nothing gets hurt....
Scorke
Old Nov 26, 2005 | 04:21 PM
DragNRacing's Avatar
Good injection systems have multiple mechanisms to alert you when there is a failure.
Old Nov 26, 2005 | 04:25 PM
SlowCar's Avatar
either cutting boost or/and switching to a less aggressive map when a fault is detected.
Old Nov 26, 2005 | 05:49 PM
yellowgsr's Avatar
yea,, I'm sure, but do they give you enough time to react?
Old Nov 26, 2005 | 05:52 PM
yellowgsr's Avatar
how can I accomplish that,with just a good tune? or do i need to get some sort of standalone or utec maybe?
Thanks guys.
Old Nov 26, 2005 | 06:22 PM
Evotech8's Avatar
I believe I read a post somewhere smc will be coming out with a failsafe boost cutting device that will drop boost to 15 psi when alky fault is detected.
